[QGIS-Developer] GRASS 7.6.1 OSGeo4W target directory
Pedro Venâncio pedrongvenancio at gmail.com
Mon Mar 25 10:38:14 PDT 2019
Hi Jurgen,
The bat files are now calling:
call "%OSGEO4W_ROOT%\apps\grass\grass-grass76\etc\env.bat"
path
%OSGEO4W_ROOT%\apps\qgis-ltr-dev\bin;%OSGEO4W_ROOT%\apps\grass\grass-grass76\lib;%OSGEO4W_ROOT%\apps\grass\grass-grass76\bin;%PATH%
which does not seem correct.
grass76 --config path
C:\OSGEO4~1\apps\grass\grass76
So, shouldn't they call:
call "%OSGEO4W_ROOT%\apps\grass\grass76\etc\env.bat"
path
%OSGEO4W_ROOT%\apps\qgis-rel-dev\bin;%OSGEO4W_ROOT%\apps\grass\grass76\lib;%OSGEO4W_ROOT%\apps\grass\grass76\bin;%PATH%
Can you take a look?
Thank you very much.
Best regards,
Pedro
Jürgen E. Fischer <jef at norbit.de> escreveu no dia sexta, 22/03/2019 à(s)
10:55:
> Hi Pedro,
> On Fri, 22. Mar 2019 at 09:49:56 +0000, Pedro Venâncio wrote:
> > GRASS 7.6.1 is now released and available at OSGeo4W, but it's directory
> is
> > now just 'grass76'.
> The path is retrieved via
> on build (but cached - but the the current build directory will be nuked
> when
> the qgis version changes).
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> https://www.norbit.de
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190325/19e7c7ae/attachment.html>
More information about the QGIS-Developer mailing list
