[QGIS-Developer] Qgis 3.6.0 fail to read shapefile with python on buster
David Marteau
dmarteau at 3liz.com
Fri Mar 29 01:41:27 PDT 2019
You need also to install the qgis-server package because libraires for the services are provided by this package:
/usr/lib/qgis/server
/usr/lib/qgis/server/libdummy.so
/usr/lib/qgis/server/libwcs.so
/usr/lib/qgis/server/libwfs.so
/usr/lib/qgis/server/libwms.so
/usr/lib/qgis/server/libwmts.so
Without these libraries the server api is not working as expected, may be these libs should be part of libqgis-serverX.Y.Z ?
So, If I summarize, in order to have a functional server API on buster, one need to install
- python3-qgis
- qgis-server (which depends on qgis-providers)
Is that a transitional scheme ?
Thanks,
> Le 29 mars 2019 à 09:13, David Marteau <dmarteau at 3liz.com> a écrit :
> Hi Jürgen,
> Thanks. Installing only python3-qgis leads to a better situation:
> ii libqgis-3d3.6.1 1:3.6.1+15buster amd64 QGIS - shared 3d library
> ii libqgis-analysis3.6.1 1:3.6.1+15buster amd64 QGIS - shared analysis library
> ii libqgis-core3.6.1 1:3.6.1+15buster amd64 QGIS - shared core library
> ii libqgis-customwidgets 1:3.6.1+15buster amd64 QGIS custom widgets for Qt Designer
> ii libqgis-gui3.6.1 1:3.6.1+15buster amd64 QGIS - shared gui library
> ii libqgis-native3.6.1 1:3.6.1+15buster amd64 QGIS - shared native gui library
> ii libqgis-server3.6.1 1:3.6.1+15buster amd64 QGIS - shared server library
> ii libqgispython3.6.1 1:3.6.1+15buster amd64 QGIS - shared Python library
> ii python3-qgis 1:3.6.1+15buster amd64 Python bindings to QGIS
> ii python3-qgis-common 1:3.6.1+15buster all Python bindings to QGIS - architectu
> But the providers are missing: you need also to install the 'qgis-providers' package which, fortunately, has dependencies
> only on 3.6.1 package version.
> David
>> Le 28 mars 2019 à 23:45, Jürgen E. Fischer <jef at norbit.de <mailto:jef at norbit.de>> a écrit :
>> Hi David,
>> On Thu, 28. Mar 2019 at 19:25:15 +0100, David Marteau wrote:
>>> I have found the problem, qgis packaging on buster is totally broken: it mixes 3.6.0 and 3.6.1 dependencies
>>> If you try to install python-qgis you get the following packages installed:
>> You should install python3-qgis.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden https://www.norbit.de <https://www.norbit.de/>
>> QGIS release manager (PSC) Germany IRC: jef on FreeNode
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Juergen Fischer, Nils Kutscher HR: Amtsgericht Aurich HRB 100827
>> Datenschutzerklaerung: https://www.norbit.de/83/ <https://www.norbit.de/83/>
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190329/9dca89ad/attachment-0001.html>
