[QGIS-Developer] Broken links to PDF manuals
Michel Stuyts michel.stuyts at edegem.be
Thu May 9 23:51:57 PDT 2019
The link is http://docs.qgis.org/3.4/pdf/en/QGIS-3.4-UserGuide-en.pdf but that redirects to https://docs.qgis.org/3.4/en/en/QGIS-3.4-UserGuide-en.pdf
The same happens to different language versions: http://docs.qgis.org/3.4/pdf/nl/QGIS-3.4-UserGuide-nl.pdf redirects to https://docs.qgis.org/3.4/en/nl/QGIS-3.4-UserGuide-nl.pdf
Michel
-----Oorspronkelijk bericht-----
Van: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> Namens Nyall Dawson
Verzonden: vrijdag 10 mei 2019 8:30
Aan: qgis-developer <qgis-developer at lists.osgeo.org>
Onderwerp: [QGIS-Developer] Broken links to PDF manuals
Hey list,
Can anyone confirm for me that the link to download PDF versions of the QGIS manual is currently broken? From https://www.qgis.org/en/docs/index.html the link leads to https://docs.qgis.org/3.4/en/en/QGIS-3.4-UserGuide-en.pdf, which returns a 404.
There's also links under https://docs.qgis.org/3.4/en/docs/ to the PDF, which point across to https://docs.qgis.org/testing/pdf/ -- but that link redirects back to https://docs.qgis.org/testing/en/docs/ and not the actual PDFs (it's also redirected from the 3.4 docs to the testing ones)
Nyall
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
