[QGIS-Developer] FIELDS_TO_COPY syntax for native:joinattributestable
Anita Graser anitagraser at gmx.at
Fri May 10 09:02:33 PDT 2019
I'm trying to figure out the syntax for using native:joinattributestable in
the modeller. Specifically, I'd like to specify the FIELDS_TO_COPY parameter.
I know from the Processing history, that the correct syntax is :
FIELDS_TO_COPY: ['NAME','USE']
but no matter how I try to enter the field names into to modeller GUI, I
always end up with either everything mashed into one field name, e.g.
FIELDS_TO_COPY: 'NAME,USE'
or escaped:
FIELDS_TO_COPY: '[\'NAME\',\'USE\']'
What's the correct way to specify the "Layer 2 fields to copy" in the
modeler GUI?
Regards,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190510/deee245c/attachment.html>
More information about the QGIS-Developer mailing list
