[QGIS-Developer] Explode HStore algorithm
wambacher at posteo.de wambacher at posteo.de
Sun May 12 09:10:40 PDT 2019
Hi
Am 12.05.19 um 17:03 schrieb Enrico Ferreguti:
> You can handle hstore using dedicated maps functions in expressions:
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/expression.html#id25
I know, but the solution:
*"In QGIS 3.4*, you can use the |htsore_to_map| expression to get a map
(dictionary) of the hstore field. Then you can use one of the map
expressions to manipulate it"
(https://gis.stackexchange.com/questions/209421/how-to-categorize-features-based-on-hstore-values-in-qgis#288550)
does not work using QGIS 3.6. I tried this without any success.
There is a solution for 3.6 in the same text, but i can't find any way
to do that.
My projects:
Admin Boundaries of the World <https://wambachers-osm.website/boundaries>
Missing Boundaries
<https://wambachers-osm.website/index.php/projekte/internationale-administrative-grenzen/missing-boundaries>
Emergency Map <https://wambachers-osm.website/emergency>
Postal Code Map (Germany only) <https://wambachers-osm.website/plz>
Fools (QA for zipcodes in Germany) <https://wambachers-osm.website/fools>
Postcode Boundaries of Germany <https://wambachers-osm.website/pcoundaries>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190512/f27411fa/attachment.html>
More information about the QGIS-Developer mailing list
