[QGIS-Developer] How to use postProcessLayer in plugin processing
Nyall Dawson nyall.dawson at gmail.com
Thu May 16 16:13:39 PDT 2019
On Thu, 16 May 2019 at 18:33, René-Luc Dhont <rldhont at gmail.com> wrote:
> Thanks, this link is helpful
> https://gist.github.com/nyalldawson/26c091dd48b4f8bf56f172efe22cf75f
> It contains a hack to work around sip bug!
Hey Matthias, on this hack -- is it the same issue as you fixed a
while back for registry instances?
Nyall
> Regards,
> René-Luc
> Le 16/05/2019 à 10:25, Tom Chadwin a écrit :
> > Don't know if any of the links in this reply from Nyall are of any use?
> > https://lists.osgeo.org/pipermail/qgis-developer/2018-September/054480.html
> > Tom
> > Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> > Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
