[QGIS-Developer] Help fixing code for gcc 4.8
Henrik Krohns hege at hege.li
Wed May 22 10:40:40 PDT 2019
Thanks, it worked, so simple..
Are fixes like this good canditate to actually raise an issue? I have no clue
on all the C++ versions etc and what stuff is legacy not intended to use
these days..
But if I manage to get this running I'll post all my patches somewhere.
On Wed, May 22, 2019 at 05:40:45PM +0200, Alessandro Pasotti wrote:
> Hi Henrik,
> Try to replace {} with (), such as:
> const auto treeLayer ( static_cast<const QgsLayerTreeLayer *>( childNode ) );
> On Wed, May 22, 2019 at 4:42 PM Henrik Krohns <[1]hege at hege.li> wrote:
>     Hello,
>     I've been trying to compile QGis on RHEL7 / GCC 4.8.5 all day.  It seems
>     lots of code assume newer compiler.  I've fixed many cases already, but
>     here's something I can't manage..  not really proficient in C++..
>     src/server/services/wms/qgswmsgetcapabilities.cpp: In function 'bool
>     QgsWms::hasQueryableChildren(const QgsLayerTreeNode*, const QStringList&)':
>     src/server/services/wms/qgswmsgetcapabilities.cpp:1893:31: error: base
>     operand of '->' has non-pointer type 'const std::initializer_list<const
>     QgsLayerTreeLayer* const>'
>            const auto l { treeLayer->layer() };
>     src/server/services/wms/qgswmsgetcapabilities.cpp:1893:41: error: unable to
>     deduce 'const std::initializer_list<const auto>' from '{<expression error>}
>     The code..
>         else if ( childNode->nodeType() == QgsLayerTreeNode::NodeLayer )
>           const auto treeLayer { static_cast<const QgsLayerTreeLayer *>(
>     childNode ) };
>           return ! wmsRestrictedLayers.contains( l->name() ) && l->flags
>     ().testFlag( QgsMapLayer::Identifiable );
>     Any ideas how to rewrite?
>     Cheers,
>     Henrik
>     _______________________________________________
>     QGIS-Developer mailing list
>     [2]QGIS-Developer at lists.osgeo.org
>     List info: [3]https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: [4]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3:   [5]www.itopen.it
> References:
> [1] mailto:hege at hege.li
> [2] mailto:QGIS-Developer at lists.osgeo.org
> [3] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [4] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [5] http://www.itopen.it/
More information about the QGIS-Developer mailing list
