[QGIS-Developer] issues when building QGIS in Docker with Qt 5.10+, help from Docker experts
Daniele Viganò daniele at vigano.me
Sun May 26 23:01:05 PDT 2019
Just an update: it looks like that statx() is now availbale in 18.04
out-of-the-box:
https://bugs.launchpad.net/ubuntu/+source/docker.io/+bug/1755250
Daniele
On Mon, May 27, 2019 at 7:49 AM Daniele Viganò <daniele at vigano.me> wrote:
> Hi Denis,
> we had the same issue with our QGIS Server Docker containers (see
> https://github.com/gem/oq-qgis-server/issues/1). Fedora based containers
> use Qt 5.11 thus they need statx().
> I did not found a 'final' solution: to be able to use statx() you need, on
> the host, Docker 18.04+ _and_ libseccomp2_2.3.1+ which are available when
> using a recent Fedora host but not, for example, Ubuntu < 18.10. I know
> that Marco Benasocchi was able to use libseccomp2_2.3.1 deb package from
> 18.10 on 18.04, but I don't know if that works fine on 16.04 (Xenial) which
> runs on Travis.
> The 'official' answer that I got from the Qt guys is that Qt is smart and
> discovers automatically the availability of statx() at compile time (and
> there's also a flag to forcefully disable support for it), but the problem
> here is that Qt has been compiled on a system that supports statx() so Qt
> expects it availability; instead in the runntime environment (Docker) all
> the conditions to use statx() are satisfied, but then the request is
> blocked by seecomp policies.
> Daniele
> On Mon, May 27, 2019 at 6:47 AM Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
>> Hi all,
>> I am trying to update the base Docker image from Cosmic to Disco to get a
>> more recent SIP version.
>> Before Cosmic Docker was building fine on Travis with Trusty.
>> I updated the Docker image to Disco and hit a timeout when building sip
>> files for QGIS.
>> So, I tried to update the Travis dist to Xenial, and now I get this issue:
>> clang: error: no such file or directory: 'src/native/moc_qgsnative.cpp'
>> This seems to be a known issue in Qt 5.10+ which requires statx calls:
>> From the Qt release notes (
>> https://code.qt.io/cgit/qt/qtbase.git/tree/dist/changes-5.10.0#n502):
>> Qt uses the statx(2) system call for obtaining file information on
>>    kernels 4.12 and later. Some older container systems install system call
>>    protection rules that do not include this system call. If you experience
>>    problems running Qt applications inside containers (such as the report of
>>    a file not existing when it does), ensure the statx(2) is allowed in the
>>    container configuration.
>> I found some information saying that this could be solved by using the
>> privileged mode when doing docker run.
>> But in our case, the QGIS build is made within the Docker build (and not
>> docker run).
>> From the Docker docs, it seems that building has full capabilities.
>> I don't really know what to look for. If anyone has a hint, it is more
>> than welcome.
>> Cheers,
>> Denis
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> *Daniele Viganò*
> http://daniele.vigano.me
*Daniele Viganò*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190527/bffd5516/attachment.html>
More information about the QGIS-Developer mailing list
