[QGIS-Developer] Getting the values of other algorithms and parameters in processing's modeller
Tim Sutton tim at kartoza.com
Mon Nov 11 23:35:53 PST 2019
Hi
> On 12 Nov 2019, at 08:10, Alexander Bruy <alexander.bruy at gmail.com> wrote:
> Hi Tim,
> if I'm not mistaken, these inputs only available inside expression editor when
> it opened from a modeler algorithm. And they are added as top-level items,
> and don't belong to any group.
Ah thanks you are right! Adding the Field Calculator algorithm for example lets me see it:
But I got other issues now:
I can’t get my expression to validate:
attribute(
get_feature(  @datatable , 'id',  @foreignkeycolumn), 'uuid’)
It validates when I substitute @datatable instead of a hard coded string, but not when I substitute @foreignkeycolumn instead of a hard coded string.
Trying to run it anyway (unsurprisingly) gives:
QGIS version: 3.10.0-A Coruña
QGIS code revision: 6c816b4204
Qt version: 5.12.3
GDAL version: 2.4.1
GEOS version: 3.7.2-CAPI-1.11.2 b55d2125
PROJ version: Rel. 5.2.0, September 15th, 2018
Processing algorithm…
Algorithm 'Convert Lookup To UUID' starting…
Input parameters:
{ 'datatable' : '/Users/timlinux/gisdata/MaceiraMergin/Maceira/smallholding.gpkg|layername=structures', 'foreignkeycolumn' : 'wall_type_id', 'lookuptable' : '/Users/timlinux/gisdata/MaceiraMergin/Maceira/smallholding.gpkg|layername=wall_type' }
Prepare algorithm: qgis:fieldcalculator_1
Running Field calculator [1/1]
Input Parameters:
{ FIELD_LENGTH: 99, FIELD_NAME: '_uuid', FIELD_PRECISION: 3, FIELD_TYPE: 2, FORMULA: 'attribute(\nget_feature( @datatable , \'id\', @foreignkeycolumn), \'uuid’)', INPUT: '/Users/timlinux/gisdata/MaceiraMergin/Maceira/smallholding.gpkg|layername=structures', NEW_FIELD: True, OUTPUT: 'memory:Calculated' }
No root node! Parsing failed?
OK. Execution took 0.413 s (1 outputs).
Model processed OK. Executed 1 algorithms total in 0.514 s.
Execution completed in 0.58 seconds
Results:
Loading resulting layers
Algorithm 'Convert Lookup To UUID’ finished
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
I'd love to connect. Here's my calendar link <https://calendly.com/timlinux> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191112/fd79f7e6/attachment-0001.html>
Name: Screenshot 2019-11-12 at 08.21.35.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191112/fd79f7e6/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191112/fd79f7e6/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
