[QGIS-Developer] Problem installing plugins from own repository
Borys Jurgiel lists at borysjurgiel.pl
Wed Oct 2 14:47:32 PDT 2019
Dnia środa, 2 października 2019 07:20:51 CEST Denis Rouzaud pisze:
> Hi all,
> It this is of any help, I have realized that naming the file plugin.zip or
> plugin-x.y.z.zip is failing while plugin.x.y.z.zip actually works.
The plugin.zip should work (and it works for me), as the suffix is optional.
For the latter, it seems to be confusing you can only use dot, not a dash. So
maybe it's a high time to fix it:
https://github.com/qgis/QGIS/pull/32100
Borys
More information about the QGIS-Developer mailing list
