[QGIS-Developer] QGIS aborted when opened (randomly)
Nyall Dawson nyall.dawson at gmail.com
Wed Oct 2 16:50:00 PDT 2019
On Wed, 2 Oct 2019 at 16:54, matteo <matteo.ghetta at gmail.com> wrote:
> Hi devs,
> I'm facing a very very very strange situation. I have 2 QGIS installed
> (3.4 from package and master compiled on debian sid).
How old is your master build? This looks a little like something which
may have been fixed by Martin ~ 3-4 weeks ago.
Nyall
> When I switch on my computer (I did not update nothing, no QGIS, no
> recompiled QGIS no update on debian in the last 2 weeks), when I try to
> open both QGIS I SOMETIMES get this error (calling qgis from package,
> same error for master). And QGIS died.
> If I try and retry, SOMETIMES I can open it. No other software are
> opened. Any clue?
> Thanks
> Matteo
> matteo at debian:~$ qgis
> /usr/lib/python3/dist-packages/qgis/core/additions/qgsfunction.py:107:
> DeprecationWarning: inspect.getargspec() is deprecated since Python 3.0,
> use inspect.signature() or inspect.getfullargspec()
>   args = inspect.getargspec(function).args
> /usr/lib/python3/dist-packages/qgis/utils.py:685: DeprecationWarning:
> the imp module is deprecated in favour of importlib; see the module's
> documentation for alternative uses
>   mod = _builtin_import(name, globals, locals, fromlist, level)
> QGIS died on signal 11[New LWP 2996]
> [New LWP 2997]
> [New LWP 2998]
> [New LWP 2999]
> [New LWP 3000]
> [New LWP 3002]
> [New LWP 3004]
> [New LWP 3005]
> [New LWP 3140]
> [New LWP 3141]
> [New LWP 3144]
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> 0x00007fceb13d9640 in ?? () from
> /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> [Current thread is 1 (Thread 0x7fcea1cdce40 (LWP 2994))]
> #0  0x00007fceb13d9640 in ?? () from
> No symbol table info available.
> #1  0x00007fceb13c4305 in ?? () from
> #2  0x00007fceb13c4bfc in ?? () from
> #3  0x00007fceb13c78fe in ?? () from
> #4  0x00007fceb140bcfa in ?? () from
> #5  0x00007fceb1443404 in ?? () from
> #6  0x00007fceb14432c0 in ?? () from
> #7  0x00007fceb1443550 in ?? () from
> #8  0x00007fceb1472c17 in ?? () from
> #9  0x00007fceb14764ce in ?? () from
> #10 0x00007fceb13423d8 in QLayoutPrivate::doResize(QSize const&) () from
> #11 0x00007fceb1343469 in QLayout::activate() () from
> #12 0x00007fceb13264e6 in QApplicationPrivate::notify_helper(QObject*,
> QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
> #13 0x00007fceb132d9b0 in QApplication::notify(QObject*, QEvent*) ()
> #14 0x00007fceb1dbfa0b in QgsApplication::notify(QObject*, QEvent*) ()
> from /usr/lib/libqgis_core.so.3.4.12
> #15 0x00007fceb09aa029 in QCoreApplication::notifyInternal2(QObject*,
> QEvent*) () from /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
> #16 0x00007fceb09ad00b in
> QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)
> #17 0x00007fceb09fbda3 in ?? () from
> #18 0x00007fcea9905ebd in g_main_context_dispatch () from
> /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
> #19 0x00007fcea9906140 in ?? () from
> #20 0x00007fcea99061cf in g_main_context_iteration () from
> #21 0x00007fceb09fb454 in
> QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)
> #22 0x00007fcea0e77391 in ?? () from
> /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
> #23 0x00007fceb350285d in QgisApp::QgisApp(QSplashScreen*, bool, bool,
> QString const&, QString const&, QWidget*, QFlags<Qt::WindowType>) ()
> from /usr/lib/libqgis_app.so.3.4.12
> #24 0x000055a001cb056f in ?? ()
> #25 0x00007fceb03b3bbb in __libc_start_main (main=0x55a001cae3c0,
> argc=2, argv=0x7ffee1f4e258, init=<optimized out>, fini=<optimized out>,
> rtld_fini=<optimized out>, stack_end=0x7ffee1f4e248) at
> ../csu/libc-start.c:308
>         self = <optimized out>
>         result = <optimized out>
>         unwind_buf = {cancel_jmp_buf = {{jmp_buf = {0,
> -6572917756161359799, 94145713223232, 140732689343056, 0, 0,
> -1119832396317523895, -1146960219580727223}, mask_was_saved = 0}}, priv
> = {pad = {0x0, 0x0, 0x7ffee1f4e270, 0x7fceb3d9e190}, data = {prev = 0x0,
> cleanup = 0x0, canceltype = -504044944}}}
>         not_first_call = <optimized out>
> #26 0x000055a001cb366a in _start ()
> [Inferior 1 (process 2994) detached]
> gdb returned 0
> Aborted
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
