[QGIS-Developer] Build error: qgsspatialiteprovider.cpp undefined reference to `sqlite3_column_table_name'
Sinan Bulut sbulut at 3vgeomatics.com
Wed Sep 11 19:56:33 PDT 2019
After some googling, it turned out that sqlite should be compiled with
SQLITE_ENABLE_COLUMN_METADATA preprocessor flag as mentioned in
https://sqlite.org/compile.html. It would be very useful if this detail is
added to the installation instructions. After this fix,  QGIS build
successfully completed.
On Wed, Sep 11, 2019 at 1:28 PM Sinan Bulut <sbulut at 3vgeomatics.com> wrote:
> It seems the formatting of my previous email was modified during
> transmission. So, below I am attaching the cmake configuration summary.
> Also attached is the build log. Note in these files I simplified the long
> software installation prefix from "/disk/..." to simply '/disk'
> Thank you in advance for you help!
> On Tue, Sep 10, 2019 at 11:11 AM Sinan Bulut <sbulut at 3vgeomatics.com>
> wrote:
>> Hi all,
>> I am trying to build QGIS  from source in Linux. In the process I am
>> getting the following error:
>> *   11979
>>  CMakeFiles/spatialiteprovider.dir/qgsspatialiteprovider.cpp.o: In
>>      function `QgsSpatiaLiteProvider::checkLayerType()':  >> 11980
>>  /cache/sbulut/spack-stage/qgis-3.8.1-d3sanusy3l7fa7br72lkqgfzaeqc
>>     gvjj/spack-src/src/providers/spatialite/qgsspatialiteprovider.cpp
>>         :4691: undefined reference to `sqlite3_column_table_name'  >> 11981
>>    collect2: error: ld returned 1 exit status  >> 11982    make[2]: ***
>> [output/lib/qgis/plugins/libspatialiteprovider.so] E              rror 1*
>> I would really appreciate some help.
>> Cmake configuration output is:
>> *-- Cache
>> valuesBINDINGS_GLOBAL_INSTALL:BOOL=FALSEBISON_EXECUTABLE:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/bison-3.0.5-pphkqxfee3diphblp3cowglecwh4czdp/bin/bisonBUILD_TESTING:BOOL=ONCCACHE_FOUND:FILEPATH=CCACHE_FOUND-NOTFOUNDCMAKE_BUILD_TYPE:STRING=RelWithDebInfoCMAKE_ENABLE:BOOL=ONCMAKE_INSTALL_PREFIX:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjmCMAKE_INSTALL_RPATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libbsd-0.9.1-dyl2vvvtdc5kh3m54fn4qoeygl57jkve/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/json-c-0.13.1-rw2ccihpjzuwpliphgzzm5fdcdl3pvcl/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libgeotiff-1.4.3-irbocdu7a46pra2w5pry6kidhu2jodl4/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libtiff-4.0.10-3yg5asc6gbydkygungpzrngjeazarfs2/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xz-5.2.4-vewnijktsjco3mbf2ycv6irlvlur46uq/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/zlib-1.2.11-25pskdmfdd52x3ewomarucg3eu6mswte/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/readline-7.0-i7lun5u3bo6g2lzux5u4acj44git37a4/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/ncurses-6.1-svwt4yh6tdtt7qtfuefht5d2bpll3f2p/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/freexl-1.0.5-lhvygj44p4qf2dwn2vyk43vgczjnwsj5/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/openssl-1.1.1b-yve6linxesmf5ynifakldny7lvl7fqrb/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/bzip2-1.0.8-mhidm2g4rrgf4f5gwpfcr5ginof26cfb/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdbm-1.18.1-uuaf3p4z4exk2ihi2wz54cugd34zhnmc/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gettext-0.19.8.1-5semcqgu6zyde443l7krttz3hjcdcwyv/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxml2-2.9.9-eivopfmxityds3u5eiy5oaldlxj3qzk3/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libiconv-1.15-zcopnqqheh3vbmlybsrltd4wj246vt64/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libffi-3.2.1-imfzbzcglr6k4rst2l7zk55ozwumehmd/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/dbus-1.12.8-ncx6bvfomsvswh72pya2jkvy5xjeeq3r/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/glib-2.56.3-gbmrmjjl5bi4dj32anhlvmxilmbhfprb/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pcre-8.42-3utfouiv6d3lfevuyujknnesugyyqqnk/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/double-conversion-2.0.1-7ycc2v3ldaynxsv6sacztkshhprsahoz/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/fontconfig-2.12.3-f6wln5spslatlsdkqhcvf7lnihdr2axk/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/font-util-1.3.2-q53vtsbmlomlkzivvb23ygmz4ibwicds/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/freetype-2.9.1-ozdurnycg4s2fhabxutfi7eoetrlyzxn/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libpng-1.6.34-milcr4breerhkz5bo3iskwxb2xank4sz/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/harfbuzz-2.3.1-v5gzjngzd2pvc7tg3eohmovo445qndir/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/cairo-1.16.0-uyv25dnwjeb5f5jpjn4qxuoqs53kgpob/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pixman-0.38.0-tz2pwy5opv67qnmrcb2cfodm36mk5qbz/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/icu4c-64.1-yfpzkt6lphbpbbibq3usei5fwjwrrfrp/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libmng-2.0.3-mnfjnd6ekvqhjleankz4hlytfv2d4z4d/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/lcms-2.9-kz4jvl36axs6o4jam73u2zabm6fnlzpu/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libx11-1.6.7-x2yopo37atbfrhwkxukar3ep3yrxiqlp/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/kbproto-1.0.7-ahe42hqnlpckswujtljjx2gpz22qk6vn/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxcb-1.13-3lnuly4szk67d7rxi67omzrvcffnrjsv/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libpthread-stubs-0.4-5hapw23celfhds7vgodxus5kag3bkct6/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxau-1.0.8-vfq3u2pzceaerfzyc2qc427nwogquepe/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xproto-7.0.31-6hdy5fp7v5cm2locbre5nqykczwgzltc/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxdmcp-1.1.2-dhfogcdfrrxe663btar3quv4q4xbpd4n/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xextproto-7.3.0-5b47ttepewybjbsojrc2zcfuztgkv5dh/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxkbcommon-0.8.2-rpc25scjaafjg6g6qzbk5nrcblrnaxwq/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/mesa-18.3.6-vdrrpxyvhxzykhknyn5y2wx2yuylz2xa/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libxext-1.3.3-b5wyw67ycgbb3hvkqs775jlrejgmgtbh/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/llvm-8.0.0-4ehepghgagyptkkbdpbwhbavr3blvary/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/binutils-2.32-uenxjpsx2w3hw2qkgdhcm2vlbmtmvjwj/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libedit-3.1-20170329-6qtkllhibhos2ggkj75mqje26nw4oftx/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pcre2-10.31-7sf7mbvnkn5numykdri6lyousgso5yfi/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-image-0.4.0-v3u4zpinbj3d6etu7mkog6zy7yxadftp/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-0.4.0-uooyrh4wijr6zz6bclbkhfx67fcdo33b/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-keysyms-0.4.0-idejxzhv5eo5m6neaerx232mitecstip/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-renderutil-0.3.9-evxsjsdov2ejpey6fey4iz3tmbwdssgh/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/xcb-util-wm-0.4.1-hjzc5mctna3lnacbirdjcvvpxy7jdud3/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qjson-0.9.0-sjy3h7monuilnmdk2xy56qrqnnjcarcg/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libsecret-0.18.8-4wtijixagq33esbwskhotmromadblpjg/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gobject-introspection-1.56.1-o64zy43idux7mllglqyfw4tqv2x7earr/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libgcrypt-1.8.4-o4ax3k3xkn7qcwsyahsz6tu6hnj4zlrn/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libgpg-error-1.36-bggto6d7niqmtfac5r5nvdoaaux24ztt/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwtpolar-1.1.1-vcw6fxzh42vdmrj3f74z36f2omvn66gi/lib;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libjpeg-turbo-2.0.2-ku6fmszupmoh7kf2ele4hhuvlvwsh5nw/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libffi-3.2.1-imfzbzcglr6k4rst2l7zk55ozwumehmd/lib64;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco/lib64CMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=FALSECMAKE_PREFIX_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qjson-0.9.0-sjy3h7monuilnmdk2xy56qrqnnjcarcg;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/cmake-3.15.1-gxyqb6bcuppyki7tajwhbfchkwarurjf;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-requests-2.21.0-4sanp2fu6cwhjagq36pmjlrcwuz2blnm;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/flex-2.6.4-4i5jekvrmxofj2xuqwmfie5l6zfdvxjc;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwtpolar-1.1.1-vcw6fxzh42vdmrj3f74z36f2omvn66gi;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-psycopg2-2.7.5-ei5cxbwiunktqqooofxe65ylwnsaovhv;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/bison-3.0.5-pphkqxfee3diphblp3cowglecwh4czdp;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow;/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/pkg-config-0.29.2-ve3sm4pl352lbca2f563zyjpc6eq4hviCXX_EXTRA_FLAGS:STRING=DISABLE_DEPRECATED:BOOL=FALSEENABLE_COVERAGE:BOOL=FALSEENABLE_MODELTEST:BOOL=FALSEENABLE_MSSQLTEST:BOOL=FALSEENABLE_ORACLETEST:BOOL=FALSEENABLE_PGTEST:BOOL=FALSEENABLE_TESTS:BOOL=TRUEEXIV2_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney/includeEXIV2_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/exiv2-0.27.2-hqeuxdfovkuai66iji53voao6gdzdney/lib64/libexiv2.soEXPAT_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i/includeEXPAT_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/expat-2.2.5-uvmuz6bjnkrrt73a5mj7qpsseb7yan6i/lib/libexpat.soFLEX_EXECUTABLE:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/flex-2.6.4-4i5jekvrmxofj2xuqwmfie5l6zfdvxjc/bin/flexGDAL_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/bin/gdal-configGDAL_CONFIG_PREFER_FWTOOLS_PATH:STRING=/bin_safeGDAL_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/binGDAL_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/includeGDAL_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gdal-2.4.2-kpqvdjndldfeh6gwusklgnvppvh5xwko/lib/libgdal.soGENERATE_COVERAGE_DOCS:BOOL=FALSEGEOS_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/bin/geos-configGEOS_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/binGEOS_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/includeGEOS_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/geos-3.7.2-wemnw5dilj4gyrj7zw6qsrdwilzbd2kc/lib/libgeos_c.soGEOS_LIB_NAME_WITH_PREFIX:STRING=-lgeos_cGSL_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow/bin/gsl-configGSL_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/gsl-2.5-7jwfctxeaogtasptahktiqou5zdpcwow/binGSL_EXE_LINKER_FLAGS:STRING=-Wl,-rpath,HDF5_C_LIBRARY_dl:FILEPATH=/usr/lib64/libdl.soHDF5_C_LIBRARY_hdf5:FILEPATH=/usr/lib64/libhdf5.soHDF5_C_LIBRARY_m:FILEPATH=/usr/lib64/libm.soHDF5_C_LIBRARY_sz:FILEPATH=/usr/lib64/libsz.soHDF5_C_LIBRARY_z:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/zlib-1.2.11-25pskdmfdd52x3ewomarucg3eu6mswte/lib/libz.soLIBZIP_CONF_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/lib/pkgconfigLIBZIP_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/includeLIBZIP_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libzip-1.2.0-rtrct7sun3f354hbdj2s2h522oyqp6bo/lib/libzip.soNETCDF_INCLUDE_DIR:PATH=NETCDF_INCLUDE_DIR-NOTFOUNDNETCDF_LIBRARY:FILEPATH=NETCDF_LIBRARY-NOTFOUNDPEDANTIC:BOOL=TRUEPOSTGRESQL_PREFIX:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjsPOSTGRES_CONFIG:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/bin/pg_configPOSTGRES_CONFIG_PREFER_PATH:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/binPOSTGRES_INCLUDE_DIR:STRING=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/includePOSTGRES_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/postgresql-11.2-nxh73rprwcpeopj2busca2z4rk7eobjs/lib/libpq.soPROJ_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3/includePROJ_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/proj-5.2.0-wq6v5hhmt2rbww6spgmxsyeadkuksyg3/lib/libproj.soPYRCC_PROGRAM:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/bin/pyrcc5PYTHON_INCLUDE_PATH:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6/include/python3.7mPYTHON_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/python-3.7.4-2humwd6d3kqdrwo6gihaejl32f4cqja6/lib/libpython3.7m.so
>> <http://libpython3.7m.so>PYTHON_TEST_WRAPPER:STRING=PYUIC_PROGRAM:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/bin/pyuic5QCA_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j/include/Qca-qt5/QtCryptoQCA_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qca-2.2.1-vuxiufdrctfwzelingrj2nkv5dshyd6j/lib/libqca-qt5.soQGIS_QML_SUBDIR:STRING=qmlQGIS_SERVER_MODULE_SUBDIR:STRING=lib/qgis/serverQML_IMPORT_PATH:PATH=QSCINTILLA_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv/includeQSCINTILLA_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qscintilla-2.10.2-jchgtkttnuhq6pl2feqy4gfoyjuhb5iv/lib/libqscintilla2_qt5.soQSCI_SIP_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/py-pyqt5-5.13.0-ry6munxzies76ixn23c76m6gxsva3cu7/share/sip/PyQt5QTKEYCHAIN_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco/include/qt5keychainQTKEYCHAIN_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qtkeychain-0.9.1-qgsvqmhhzk5z35rmogtx7kaoolwc4oco/lib64/libqt5keychain.soQT_DOC_URL:STRING=http://doc.qt.io/qt-5/
>> <http://doc.qt.io/qt-5/>QT_LRELEASE_EXECUTABLE:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/bin/lreleaseQWT_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx/includeQWT_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qwt-6.1.3-v7en2faku4tn7dqhdlmq3w5diig53hbx/lib/libqwt.soQt5Concurrent_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5ConcurrentQt5Core_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5CoreQt5DBus_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5DBusQt5Gui_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5GuiQt5Network_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5NetworkQt5Positioning_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5PositioningQt5PrintSupport_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5PrintSupportQt5Qml_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5QmlQt5QuickWidgets_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5QuickWidgetsQt5Quick_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5QuickQt5SerialPort_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5SerialPortQt5Sql_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5SqlQt5Svg_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5SvgQt5Test_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5TestQt5UiTools_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5UiToolsQt5Widgets_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5WidgetsQt5Xml_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/qt-5.11.3-fx3uvmas7ehup3jtvuklqp3o6okb4lsj/lib/cmake/Qt5XmlSPATIALINDEX_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom/includeSPATIALINDEX_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialindex-1.8.5-ohzm4aezoehfsgkzcu32brclqr3uogom/lib/libspatialindex.soSPATIALITE_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut/includeSPATIALITE_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/libspatialite-4.3.0a-yfwfsh3liog4ueoj3anycl7zw4m2yiut/lib/libspatialite.soSQLITE3_INCLUDE_DIR:PATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a/includeSQLITE3_LIBRARY:FILEPATH=/disk/software/lib/hpcpm/spack/opt/spack/linux-centos7-x86_64/gcc-7.4.0/sqlite-3.26.0-tscbujc54kmrxnt3rldy67ue2qvt5t5a/lib/libsqlite3.soTXT2TAGS_EXECUTABLE:FILEPATH=TXT2TAGS_EXECUTABLE-NOTFOUNDUSE_CCACHE:BOOL=ONUSE_OPENCL:BOOL=OFFWERROR:BOOL=FALSEWITH_3D:BOOL=FALSEWITH_ANALYSIS:BOOL=TRUEWITH_APIDOC:BOOL=FALSEWITH_ASTYLE:BOOL=FALSEWITH_BINDINGS:BOOL=TRUEWITH_CUSTOM_WIDGETS:BOOL=FALSEWITH_DESKTOP:BOOL=TRUEWITH_GEOREFERENCER:BOOL=TRUEWITH_GLOBE:BOOL=FALSEWITH_GRASS7:BOOL=OFFWITH_GUI:BOOL=TRUEWITH_INTERNAL_MDAL:BOOL=TRUEWITH_INTERNAL_O2:BOOL=ONWITH_OAUTH2_PLUGIN:BOOL=TRUEWITH_ORACLE:BOOL=FALSEWITH_POSTGRESQL:BOOL=TRUEWITH_PY_COMPILE:BOOL=FALSEWITH_QSPATIALITE:BOOL=OFFWITH_QT5SERIALPORT:BOOL=TRUEWITH_QTMOBILITY:BOOL=FALSEWITH_QTWEBKIT:BOOL=OFFWITH_QUICK:BOOL=FALSEWITH_QWTPOLAR:BOOL=FALSEWITH_SERVER:BOOL=FALSEWITH_STAGED_PLUGINS:BOOL=TRUEWITH_TXT2TAGS_PDF:BOOL=FALSE_find_lib_python_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindLibPython.py_find_pyqt5_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindPyQt5.py_find_qsci_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindQsci.py_find_sip_py:FILEPATH=/cache/sbulut/spack-stage/qgis-3.8.1-mhsqhywvlsapl6kosqfnxnoo5mvegwjm/spack-src/cmake/FindSIP.py*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190911/8abd5764/attachment-0001.html>
More information about the QGIS-Developer mailing list
