[QGIS-Developer] Processing - Default Output raster&vector extensions enumerator?
Alexandre Neto senhor.neto at gmail.com
Thu Sep 19 14:02:14 PDT 2019
Hi all,
I have realized that the processing option to determine the default output
extension as moved to the advanced settings. What I find odd is that the
value type is an integer and the default values is now 0. Changing it to 1,
seems to make the default shapefiles.
If exists, where can I find the enumeration for default values? this needs
to be documented
Thanks,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190919/774e1315/attachment.html>
More information about the QGIS-Developer mailing list
