[QGIS-Developer] Making QgsRasterLayerProperties class independent again from QgisApp instance
Vincent Cloarec
vcloarec at gmail.com
Mon Sep 23 09:14:45 PDT 2019
Hello,
I have some difficulties in passing the Travis tests with this PR:
https://github.com/qgis/QGIS/pull/31942.
As I am fed up to make turning the server for nothing and reject CO2, I ask
for help.
The 'code layout' tests seem not to pass. Reading the log, I can find this
link http://tinyurl.com/yynt7m9a. Following this link, it seems the
problems come from warning: undocumented parameters and unknown command
'\TODO'.
Can anyone confirm ?
Thanks.
Vincent Cloarec
www.reos.site
Le lun. 23 sept. 2019 à 00:25, Vincent Cloarec <vcloarec at gmail.com> a
écrit :
> Hello,
> Thanks Nyall for your advice.
> I have chosen to move the raster layer properties to the gui. As the
> widget is very convenient, no reason to rebuild my own. Moreover, it
> appears there is not a lot of code to change.
> So I purpose this PR: https://github.com/qgis/QGIS/pull/31942
> The tests seem to pass for QGIS, and I have tried to import the
> QgsRasterLayerProperties class to a standalone application only using the
> gui library, it is ok.
> Vincent Cloarec
> www.reos.site
> Le jeu. 19 sept. 2019 à 00:37, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
>> On Thu, 19 Sep 2019 at 13:55, Vincent Cloarec <vcloarec at gmail.com> wrote:
>> > In standalone applications, I am using the QgsRasterLayerProperties
>> class to manage rasters displayed in the map canvas.
>> > However, since QGis 3.8, this class is no longer independent from the
>> QgisApp instance because the methode
>> QgisApp::instance()->askUserForDatumTransform() is called from the
>> QgsRasterLayerProperties instance.
>> > As in my standalone applications, I don't have QgsApp instance (no
>> need), now this applications crash when the raster layer properties widget
>> opens ...
>> > So, after a look at the Qgis code, I am thinking about to make a PR to
>> make again the QgsRasterLayerProperties independant from the QgisApp
>> instance. I think it could be possible with a static method in the QgisApp
>> class. I have to work on it.
>> Possibly -- but it's a band-aid solution only. There's a LOT of code
>> in the app library which will make assumptions that the QgisApp
>> instance is available, and that's why all this code is partitioned off
>> into the app library. app also has no stable API guarantees and you'll
>> continue to hit situations like this.
>> I'd suggest two possible alternative ways forward:
>> 1. Use the stable api classes exposes through the gui library to
>> rebuild your own raster layer properties dialog
>> 2. Submit a PR moving the raster layer properties class from app ->
>> gui and adding it to the stable API
>> Both approaches are more upfront work, but are paths to much less pain
>> and future breakage...
>> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190923/41957127/attachment-0001.html>
