[QGIS-Developer] [Qgis-user] QGIS installation error from own build
Jürgen E. Fischer jef at norbit.de
Wed Apr 22 09:20:22 PDT 2020
On Wed, 22. Apr 2020 at 21:41:04 +0530, Sachin Kumar wrote:
> When I copied my build files from qgis-test folder to
> “..\ms-windows\osgeo4w\unpacked-x86_64\apps\qgis” and copied
> “OSGeo4W/apps/qgis-test/bin/qgis.exe” to
> “..\ms-windows\osgeo4w\unpacked-x86_64\bin and rename *qgis.exe*to
> *qgis-bin*”. After that run perl creatensis.pl I get
> “QGIS-OSGeo4W-3.10.5-2-Setup-x86_64.exe”.
> After installation I get following error:
> Error loading QGIS
> Oops, looks like an error loading QGIS
> Details:
> Could not load qgis_app.dll
> Windows Error: The specified module could not be found.
> Help:
> Check C:\Program Files\QGIS 3.10\bin\qgis-bin.env for correct environment
> paths
You didn't include the postinstall batch files (at least).  Either check
package-nightly.cmd / package.cmd to see which other files are created or run
package-nightly.cmd, extract the resulting package to addons and run
creatensis.pl thereafter (excluding qgis-dev - as you would get two QGIS' in
your installer otherwise).
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200422/93e1f5fd/attachment.sig>
More information about the QGIS-Developer mailing list
