[QGIS-Developer] Buffer of lines results in "random" vertex order in buffer polygon
Nils Nolde nilsnolde at gmail.com
Thu Aug 6 10:26:40 PDT 2020
Dear devs,
I have a fairly complex geometry-(and mind-)bending workflow where I'd
ideally depend on the fact that buffering a line (regular buffer, flat
cap, miter join with almost infinite limit) would result in a
reproducible pattern for the vertex order in the resulting buffer
polygon (s. [1] for details).
I found that in 99% of the cases the first vertex of the buffered
polygon will be on the left side of the original line feature's second
vertex (which is great). That's confusing, not sure how else to put it,
but see this image for viz: https://i.imgur.com/RwvYA0g.png, showing the
vertex order of the original line features and the resulting polygon
features.
However, on a few occasions this assumption doesn't seem to hold and the
first vertex of the buffer polygon will be anywhere with respect to the
original line feature's first vertex and does not follow any pattern at
all, s. [2] for a WKT example in EPSG:25832 and buffered with 0.3 m
(it's too long for an image). On this feature, vertex 0 of the polygon
feature is on the left side of vertex 14 of the line feature, not next
to vertex 2 as for all other line features I buffered.
My question is: is that expected behavior that buffer feature vertices
can start at a sorta random place with respect to the line feature's
first vertex? Or can this be considered a minor bug?
Many thanks
Nils
[1] I want only one side of the buffered geometry and need to somehow
rotate the buffer vertex list so that the first vertex is related to the
first vertex of the line feature. I can't use singleSidedBuffer()
because that is much more likely to produce weird artifacts on sharp
kinks in the line geometry.
[2] The WKT of a feature where it's not working as I'd expect (in
EPSG:25832, buffered with 30 centimeters, flat cap, miter join and 100m
miter limit): LineString (567128.05779425 5674382.50117657,
567124.28299077 5674385.77951107, 567121.44049412 5674387.67067814,
567113.39428435 5674393.02397452, 567089.71334818 5674408.77935169,
567075.32187873 5674418.35427, 567048.09794292 5674433.92388853,
567047.26883028 5674434.39806565, 567046.22311791 5674435.0838905,
567043.6035418 5674436.80192543, 567006.05562972 5674453.08412973,
566973.94524544 5674467.01295346, 566941.83486115 5674480.9417772,
566930.00051817 5674486.07016386, 566929.97872742 5674486.07960683,
566929.33462488 5674485.86262721, 566904.04808487 5674477.3443191,
566871.1140052 5674462.85053673, 566838.17992554 5674448.35675436,
566797.46760646 5674431.84405364, 566756.75528738 5674415.33135292,
566716.04296829 5674398.8186522, 566675.33064921 5674382.30595149)
More information about the QGIS-Developer mailing list
