[QGIS-Developer] qgis_process-qgis-rel-dev System Error - Missing gdal302 and proj_7_2 dlls
Andrea Giudiceandrea andreaerdna at libero.it
Sun Aug 9 18:54:09 PDT 2020
Pedro Venâncio-2 wrote
> Hi all,
> I'm trying to set up qgis_process on a Windows machine with QGIS 3.14.1
> installed with OSGeo4W (qgis-rel-dev 3.14.1-14).
> When I do qgis_process-qgis-rel-dev in the OSGeo4W Shell, I get several
> System Errors, about missing gdal302.dll and proj_7_2.dll.
> qgis_process-qgis-rel-dev.bat is present and has:
> @echo off
> call "%~dp0\o4w_env.bat"
> call qt5_env.bat
> call py3_env.bat
> @echo off
> path %OSGEO4W_ROOT%\apps\qgis-rel-dev\bin;%PATH%
> set QGIS_PREFIX_PATH=%OSGEO4W_ROOT:\=/%/apps/qgis-rel-dev
> set GDAL_FILENAME_IS_UTF8=YES
> rem Set VSI cache to be used as buffer, see #6448
> set VSI_CACHE=TRUE
> set VSI_CACHE_SIZE=1000000
> set
> QT_PLUGIN_PATH=%OSGEO4W_ROOT%\apps\qgis-rel-dev\qtplugins;%OSGEO4W_ROOT%\apps\qt5\plugins
> set PYTHONPATH=%OSGEO4W_ROOT%\apps\qgis-rel-dev\python;%PYTHONPATH%
> "%OSGEO4W_ROOT%\apps\qgis-rel-dev\bin\qgis_process.exe" %*
> So, can it be missing paths to:
> %OSGEO4W_ROOT% \apps\proj-dev\bin\proj_7_2.dll
> %OSGEO4W_ROOT% \apps\gdal-dev\bin\gdal302.dll
> Thanks!
> Best regards,
> Pedro Venâncio
> QGIS-Developer mailing list
> QGIS-Developer at .osgeo
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Hi Pedro Venâncio,
try to substitute
call py3_env.bat
with
call gdal-dev-py3-env.bat
in qgis_process-qgis-rel-dev.bat
Regards.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
