[QGIS-Developer] qgis_process-qgis-rel-dev System Error - Missing gdal302 and proj_7_2 dlls
Pedro Venâncio pedrongvenancio at gmail.com
Mon Aug 10 01:52:19 PDT 2020
Hi Andrea,
Thank you very much! And also thanks to Jurgen!
I've done the replace and then run qgis_process-qgis-rel-dev.bat
--postinstall and it works!
Thanks again!
Best regards,
Pedro
Andrea Giudiceandrea <andreaerdna at libero.it> escreveu no dia segunda,
10/08/2020 à(s) 08:28:
> I apologize for inadvertently quoting the whole original message...
> In the meantime, the issue was fixed by Jürgen Fischer [1], so you can wait
> for the next rel-dev build or use my workaround until then.
> Regards.
> Andrea
> [1]
> https://github.com/qgis/QGIS/commit/b3147bc8b6a841d9a5e20fb43d41288e9b841ecf
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200810/e9893169/attachment.html>
More information about the QGIS-Developer mailing list
