[QGIS-Developer] Unload QgsVectorLayer/QgsrasterLayer
Nyall Dawson
nyall.dawson at gmail.com
Mon Aug 10 15:45:34 PDT 2020
On Tue, 11 Aug 2020 at 06:37, Bourdon, Jean-François (DIF)
<Jean-Francois.Bourdon at mffp.gouv.qc.ca> wrote:
> Hi list,
> I have a very simple problem: I can’t delete a file after loading it with QgsVectorLayer() or QgsRasterLayer() within a script (custom Processing Provider) as I get the error saying the file is still in use. My code to replicate:
> path_raster = "C:/temp/raster.tif"
> rlayer = QgsRasterLayer(path_raster, "flow")
> QgsProject.instance().addMapLayer(rlayer, False)
> QgsProject.instance().removeMapLayer(rlayer.id())
> os.remove(path_raster)
> However, the same code directly put inside the Python Console within QGIS works, but it won’t if used inside a Processing Provider plugin. I also tried using del rlayer without success. There is several questions about releasing QGIS’ lock on files on GIS StackExchange (e.g. here and here) but it doesn’t seem to work for everyone. Maybe it was working in version 2.X, but it fails on 3.12 (Windows 10).
I suspect your algorithm is incorrectly running in a thread. You CAN'T
do this if your algorithm directly access the project instance -- it's
not thread safe and the layers are likely not getting deleted at all.
Try returning the FlagNoThreading flag from your algorithm's flags()
override.
Nyall
> Many thanks
> Jean-François Bourdon, ing.f.
> Analyste en télédétection
> Direction des inventaires forestiers
> Ministère des Forêts, de la Faune et des Parcs
> 5700, 4e Avenue Ouest, local A-108
> Québec (Québec) G1H 6R1
> Téléphone : 418 627-8669, poste 4304
> jean-francois.bourdon at mffp.gouv.qc.ca
> mffp.gouv.qc.ca
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
