[QGIS-Developer] Inconsistencies in QGIS ini path
Richard Duivenvoorde
rdmailings at duif.net
Mon Aug 17 04:32:20 PDT 2020
On 8/17/20 9:23 AM, Tim Sutton wrote:
> On Sun, Aug 16, 2020 at 11:20 PM Nyall Dawson <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>> wrote:
> On Sun, 16 Aug 2020 at 18:28, Tim Sutton <tim at kartoza.com <mailto:tim at kartoza.com>> wrote:
> > PopOS Flatpack ini:
> > <PREFIX>/QGIS/QGIS3/profiles/<PROFILE NAME>/QGIS/QGIS3.ini
> > PopOS deb ini:
> > macOS all in one DMG ini:
> > <PREFIX>/QGIS3/profiles/<PROFILE NAME>/qgis.org/QGIS3.ini <http://qgis.org/QGIS3.ini>
> These ones are all following the operating system's guidance for
> storing local configuration. Is this an issue? I'd expect most of the
> configuration inside the user profile to be storing relative paths to
> the profile folder, not absolute. If not, do you have examples of
> settings which store absolute paths?
Hi Tim,
Only 'difference' I see is between the macOS and the other ones?
One thing to know it that because of the 'sandboxing' flatpack does not store it's stuff in the same place as a Linux distro does (in ~/.local/share).
Maybe there is some 'APPLICATION' name in the path's? And that differs on macOS dmg's?
Although:
https://github.com/qgis/QGIS/blob/master/src/core/qgsapplication.cpp#L204
looks like it is a Qt thing:
QStandardPaths::standardLocations( QStandardPaths::AppDataLocation ).value( 0 );
With me here (having both my own builds AND flatpaks), running:
QStandardPaths.standardLocations(QStandardPaths.AppDataLocation)
in the pythonconsole shows:
'/home/richard/.local/share/QGIS/QGIS3',
'/usr/share/gnome/QGIS/QGIS3',
'/home/richard/.local/share/flatpak/exports/share/QGIS/QGIS3',
'/var/lib/flatpak/exports/share/QGIS/QGIS3',
'/usr/local/share/QGIS/QGIS3',
'/usr/share/QGIS/QGIS3'
Can you test this on a mac?
IF it is different, I think it is better to adhere to Qt-standards then to build those path's ourselves?
Regards,
