[QGIS-Developer] Documentation tests failing on local machine
matteo
matteo.ghetta at gmail.com
Tue Aug 18 02:26:23 PDT 2020
Hi all,
I don't know what I'm doing wrong but when I run documentation tests on
my local machine I always get messages like:
Line 6, in geometry (setup code)
Failed example:
iface = start_qgis()
from qgis.core import (
QgsProject,
QgsVectorLayer,
# Load the countries layer
if not QgsProject.instance().mapLayersByName("countries"):
vlayer =
QgsVectorLayer("/usr/share/qgis/resources/data/world_map.gpkg|layerName=countries",
"countries", "ogr")
assert vlayer.isValid()
QgsProject.instance().addMapLayers([vlayer])
Exception raised:
File "/usr/lib/python3.8/doctest.py", line 1336, in __run
exec(compile(example.source, filename, "single",
File "<doctest geometry (setup code)[1]>", line 1, in <module>
NameError: name 'start_qgis' is not defined
1 items had failures:
2 of 2 in geometry (setup code)
***Test Failed*** 2 failures.
I've QGIS compiled and I've added this lines in the user.mk file (in
order to run test with a compiled version of QGIS instead of the default
installation):
# Root installation folder
QGIS_PREFIX_PATH = /home/matteo/dev/qgis-master/output
include venv.mk
and run the following code
make -f user.mk doctest
I followed exactly the documentation
(https://docs.qgis.org/testing/en/docs/documentation_guidelines/cookbook_guidelines.html#how-to-test-snippets-on-your-local-machine).
I get the same exact errors also with the local installation of QGIS
when running:
make -f venv.mk doctest
Some suggestions?
Cheers and thanks!
Matteo
