[QGIS-Developer] SQL in graphic modeller - Reg
Karthikeyan M kalam1993 at gmail.com
Tue Aug 18 06:12:07 PDT 2020
Hi Alexandre,
Thank you for your reply. It worked for me.
Thanks and Regards,
Karthikeyan M
On Fri, Aug 14, 2020 at 6:56 PM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hello,
> Have you tried to use the PostgreSQL execute and load algorithm from the
> Processing toolbox?
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/database.html#postgresql-execute-and-load-sql
> Another alternative is to use the Refactor fields tool, where you can
> select the columns you want to keep and in which order.
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectortable.html#refactor-fields
> Best regards,
> Alexandre Neto
> QGIS Support
> www.qcooperative.net
> A sexta, 14/08/2020, 12:23, Karthikeyan M <kalam1993 at gmail.com> escreveu:
>> Hi ,
>> I'm learning graphic modeller in QGis3. Earlier I used to select only 3
>> columns ( from 73 coloumn) of attributes by using sql query in DB manager.
>> I want to create a  model for that. Is there anyway I can use that sql
>> query to extract particular coloumn from shape files using Graphic modeller
>> Expecting your reply
>> Regards,
>> Karthikeyan M
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200818/cfb2327c/attachment.html>
More information about the QGIS-Developer mailing list
