[QGIS-Developer] No PyQGIS documentation build since mid july
DelazJ delazj at gmail.com
Wed Aug 19 14:58:43 PDT 2020
Hi Denis,
Le mer. 19 août 2020 à 06:41, Denis Rouzaud <denis.rouzaud at gmail.com> a
écrit :
> Hi Harissou,
> This is expected for 3.14 as point releases docs are built only when a new
> release is published.
Makes sense indeed.
Thanks for the update. The date is now from today but I'm not sure the
content is. Taking eg https://qgis.org/pyqgis/3.14/core/QgsVectorLayer.html
and https://qgis.org/pyqgis/master/core/QgsVectorLayer.html, you will
notice that:
- the first code sample is in Python in 3.14 and c++ in master: they all
should be Python (
https://github.com/qgis/QGIS/blob/master/src/core/qgsvectorlayer.h#L104 and
https://github.com/qgis/QGIS/blob/master/python/core/auto_generated/qgsvectorlayer.sip.in#L37
- the sections and subsections are supposed to have a special formatting (
https://github.com/qgis/QGIS/blob/master/python/core/auto_generated/qgsvectorlayer.sip.in#L44):
they are not in master, and the text is absent in 3.14. I don't know if
this is a code issue or a build issue but there's one.
Greetings,
Harrissou
But it looks like cron jobs are disabled for master on Travis (qgis/pyqgis).
> Once more, it looks like I lost access to settings on the repo. Can anyone
> grant me access again?
> Cheers,
> Denis
> Le mar. 18 août 2020 à 21:57, DelazJ <delazj at gmail.com> a écrit :
>> Hi,
>> Just to mention that pyqgis doc last update indicates for master 9th july
>> and for 3.14 22nd july. Something is broken in the build process.
>> Regards,
>> Harrissou
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200819/55e1c7e9/attachment.html>
More information about the QGIS-Developer mailing list
