[QGIS-Developer] Travis failing in QGIS-Documentation
Mathieu Pellerin nirvn.asia at gmail.com
Tue Aug 25 01:15:19 PDT 2020
Denis,
Thanks for all the work improving and fixing this.
Math
On Tue, Aug 25, 2020 at 3:12 PM Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> Hi,
> Sorry, I am somehow responsible for the failure of the recent Docker
> images on master (release branches were apparently not affected).
> The images were apparently not updated for a bit (which I didn't notice).
> I moved the Docker images creation from Travis to Github actions, and due
> to a missing check in the job, the image was pushed without QGIS built in
> it.
> There was apparently a new way of defining where the Qt 3D extras headers
> are located:
> https://github.com/qgis/QGIS/commit/46acc34e6a8263218c5c494096f3182a05c704e7#diff-6987645362d6f81263fd0a8623dacbb9R52
> This is now fixed, the image is currently building
> https://github.com/qgis/QGIS/runs/1025298753?check_suite_focus=true
> If no stupid error is present further in the job, it should be pushed
> still this morning.
> Sorry for the mess.
> Denis
> Le mar. 25 août 2020 à 09:53, matteo <matteo.ghetta at gmail.com> a écrit :
>> Hi all,
>> sorry for cross posting and sorry if I missed some existing discussion
>> on this topic.
>> I don't think anybody introduced some strange commit but it seems that
>> the Travis check is always failing even with PR that don't code snippet
>> at all.
>> The error seems related directly with the environment:
>> https://travis-ci.org/github/qgis/QGIS-Documentation/builds/720902932#L694
>> Exception raised:
>>     Traceback (most recent call last):
>>       File "/usr/lib/python3.8/doctest.py", line 1329, in __run
>>         exec(compile(example.source, filename, "single",
>>       File "<doctest geometry (setup code)[0]>", line 22, in <module>
>>         from qgis.testing import start_app
>>     ModuleNotFoundError: No module named 'qgis'
>> Any Travis guru out here? :)
>> Cheers and thanks
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200825/f44589ff/attachment.html>
More information about the QGIS-Developer mailing list
