[QGIS-Developer] Travis failing in QGIS-Documentation
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Aug 26 21:41:22 PDT 2020
Hi Matteo,
The Docker has indeed been fixed for about 2 days (and PyQGIS API docs are
being built again since this morning).
Regarding the segmentation you mention, I don't see this is related to the
Docker image.
It's a bit hard to know from this what is happening from the log.
Can you run it locally?
Cheers,
Denis
Le mer. 26 août 2020 à 15:15, matteo <matteo.ghetta at gmail.com> a écrit :
> Hi Denis,
> I restarted a build but it is still failing do due a segmentation fault:
> https://travis-ci.org/github/qgis/QGIS-Documentation/builds/720594748#L1128
> Is it sill work in progress?
> Cheers and thanks
> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200827/70483ccf/attachment.html>
