[QGIS-Developer] Coordinates of a pixel
Miguel-Ángel Fas-Millán fas.millan at gmail.com
Mon Aug 31 18:30:57 PDT 2020
Thanks for your reply. Well, let me provide more details to explain why I
was asking that.
I have a DSM, with its xllcenter/yllcenter coordinates and I need to know
the coordinates of the (in this case) center of any of the squares/cells
(which, maybe wrongly, I called pixels) represented by this dataset. To
that I've been using a function equivalent to the provided by this
calculator: https://geodesy.noaa.gov/cgi-bin/Inv_Fwd/forward2.prl , which
takes as parameters the starting point, azimuth, distance, and returns the
ending coordinates.
For instance, I want to calculate the coordinates of the first cell of the
dataset (top left of the matrix). So I do:
calculateEndingGlobalCoordinates(Ellipsoid.*WGS84*, start_coords, 0.0,
nrows*cellsize) //0.0 for north
The problem is that it returns a value with a latitude that seems ok, but a
wrong longitude. When I place that coordinate in QGIS, it is out of the
image, quite at left of the top left corner.
Unsurprisingly, if I place the coordinates obtained with this method (or
with the online calculator mentioned) in google maps, to check if it makes
sense looking at what's there in the satellite images, they make no sense
at all.
However, if I take the coordinates appearing in QGIS when I hover one of
the cells, and place them in google maps, it makes perfect sense. With a
few meters of difference, but well, at least it is on the right track. (I
am that sure because I took as reference a ATC tower, which is the highest
element in a wide area).
That's why I wanted to check what's the difference between the mentioned
method I was using and whatever is made in the code to return those quite
correct coordinates.
El mar., 1 sept. 2020 a las 0:01, Charles Dixon-Paver (<charles at kartoza.com>)
escribió:
> Someone can correct me if I'm wrong, but I think there's a
> misunderstanding here of how this raster data is handled in a GIS. From my
> understanding of the question, I don't know that what you're asking for is
> available "in the code" the way you expect.
> The coordinates are showing the position of the cursor relative to the
> origin of the assigned coordinate reference system. The raster data is
> "projected" onto that reference system, which assigns positions to some
> points on the image and stretches, rotates or distorts the image in
> accordance with the images affine parameters that ensure all the different
> parts of the image remain spatially correct. How the GIS knows where to get
> these parameters varies between data types and file formats.
> Playing around with the georeferencer tool in QGIS should give you a
> pretty clear understanding of how this "projection" works.
> There are ways to get the coordinates of a position or pixel within an
> image programmatically, the easiest of which that I can think of is using
> values from a world file [1] with an xy position (in pixels) of the pixel
> of interest. The code required for achieving this, however, is probably
> going to be dependant on a wide variety of factors (not least of all the
> CRS units and pixel size). Alternatively, you could likely grab the
> coordinate position of a pixel from within a QGIS project, but that doesn't
> seem to be what you're after. Perhaps a developer familiar with the GDAL or
> QGIS code bases can point you in the direction of some wizardry that will
> achieve what it is you are looking for without a clearer understanding of
> your use case though.
> [1] https://en.wikipedia.org/wiki/World_file
> On Mon, 31 Aug 2020 at 19:57, Miguel-Ángel Fas-Millán <
> fas.millan at gmail.com> wrote:
>> Hi all,
>> New around here and as a QGIS user. I need to find something in the
>> code, I hope you can help me.
>> When you open a DSM and place the mouse on any pixel, you can see the
>> coordinates of that point. Could someone tell me where in the code is made
>> the calculation of those coordinates?
>> Regards,
>> Angel
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200901/b325092b/attachment.html>
More information about the QGIS-Developer mailing list
