[QGIS-Developer] Potential vulnerabilities
Jonathan Moules jonathan-lists at lightpear.com
Sat Feb 1 13:25:51 PST 2020
I can't comment on the security aspect, but at the very least there's a
bug in the WMS compliance. For the GetCapabilities URL it should be
returning an XML Service Exception (because it has an invalid SERVICE
value), not a HTTP 500.
I.e., the same request to a (random) GeoServer box shows the sort of
thing that should be coming back:
http://si.icnf.pt/geoserver/POEM/ows?REQUEST=GetCapabilities&SERVICE=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&VERSION=1.3.0
On 2020-02-01 18:33, nadiaspit wrote:
> Hi,
> I am a student of Cybersecurity Master at University of Pisa. My final
> project work is about a Security Test of an installation of qgis server +
> lizmap web client.
> At a first analysis, I found out that lizmap web client is vulnerable to
> "Buffer overflow attack"
> https://www.owasp.org/index.php/Buffer_overflow_attack
> The problem:
> "Potential Buffer Overflow. The script closed the connection and threw a 500
> Internal Server Error"
> The solution:
> "Rewrite the background program using proper return length checking. This
> will require a recompile of the background executable."
> Here you can view the  report
> <https://drive.google.com/file/d/12s-akDIr9s127kw6MSYKRp1ph29gY_u3/view?usp=sharing>
> I also posted this question to Lizmap web client Github: Is Buffer Overflow
> vulnerability a false positive for Lizmap web client?
> They suggested to ask to this group.
> Any help would be very appreciated.
> Kind Regards,
> Nadia Spitilli
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
