[QGIS-Developer] run algorithm pyQgis 3
Cibeles Redondo Veloso cibelesredondo at gmail.com
Wed Feb 12 00:05:11 PST 2020
Dear Matteo,
Thank you for your answer.
I using this code to check all the processing available with PyQGIS3
> for i in QgsApplication.processingRegistry().algorithms():
>     print("{}:{} --> {}".format(i.provider().name(), i.name(),
> i.displayName()))
In the result there is no "saga:triangulation".
Also, I already try algorithmHelp('saga:triangulation')
[image: image.png]
There is no result.
That is the reason why I am writing here. I search for several days and I
do not find anything, also in StackOverflow and StackEchange.
Thank you in advance!
El mié., 12 feb. 2020 a las 7:34, matteo (<matteo.ghetta at gmail.com>)
escribió:
> Hi,
> > I am trying to convert a script from PyQGIS 2 to PyQGIS 3
> > In the original script, the author used
> > processing.runalgorithm("saga:triangulation", parameters). Now, I am
> > trying to use it as same as possible with PyQGIS3 but I am not finding
> > anything similar:
> >  1. I am using processing.run instead of processing.runalgorithm
> >  2. I am aware that there is no SAGA API for Python 3
> >  3.  The objective of the code is change as less as possible. That's why
> >     I am not looking for other solutions (except if you tell me there is
> >     no similar solution, of course)
> > Maybe someone knows what can I do in this case?
> check which parameters have been specified: it might be a different
> number of them between QGIS2 and QGIS3.
> Type processing.algorithmHelp('saga:triangulation') to see the list and
> type of each single parameter.
> A complete guide of how to use algorithm from the console is n the user
> manual:
> https://docs.qgis.org/testing/en/docs/user_manual/processing/console.html
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200212/b073d16c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200212/b073d16c/attachment-0001.png>
More information about the QGIS-Developer mailing list
