[QGIS-Developer] Zoom to Scale Plugin - Should we include it on qgis.org?
C Hamilton adenaculture at gmail.com
Thu Feb 20 12:21:45 PST 2020
Richard,
Thanks for that information. I meant plugins.qgis.org. From the URL you
sent it looks like it has many of the components and it gives me ideas for
EPSG:4326.
Unless someone else is working on this I will submit a plugin after I see
if I can make it work with other CRS tile caches.
Thanks,
Calvin
On Thu, Feb 20, 2020 at 2:58 PM Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> Hi Chris,
> One year ago I proposed the following: a tree embedded widget to be used
> for WMS/WMTS layers. It uses the functionality which is in the Juergens
> Tile Scale Panel:
> http://www.qgis.nl/2019/02/14/about-layer-tree-embedded-widgets-and-have-your-wmts-always-crispy-sharp/?lang=en
> Probably you mean something else? As it is not resizing the servertiles,
> but 'clicking' to the right scales (coming from the capability
> documents) of the active layer.
> If you mean plugins.qgis.org when you talk 'adding it to the repo' I
> would say yes! Why not?
> If you say add it by default to QGIS, I'd say: let's first see and check
> it out as plugin :-)
> Also (see discussion about resources plugin) adding python plugins to
> QGIS installs has some drawbacks.
> Regards,
> On 2/20/20 8:37 PM, C Hamilton wrote:
> > We have written a plugin that fixes the scale of the QGIS canvas to
> > match the integral size of EPSG:3857 map server tiles. This way there is
> > no degradation of the images by transformation. This has some
> > similarities to the QGIS 2 plugin called Tile Map Scale Plugin which was
> > never updated for QGIS 3.
> > This only works with EPSG:3857 projections. I wish I could figure out a
> > way to also match an EPSG:4326 tile cache to the canvas scale size, but
> > I cannot use the map scale to calculate this because it changes as you
> > move around.
> > Would you be interested in having this plugin added into the QGIS repo?
> > Unlike the Tile Map Scale Plugin ours only has a single toggle button to
> > lock or unlock the QGIS scale to one of the predefined scales.
> > Let me know what you think?
> > Thanks,
> > Calvin
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200220/457863c4/attachment.html>
More information about the QGIS-Developer mailing list
