[QGIS-Developer] GPKG modified by QgsServer, with qgsogrprovider having Wal set to false
Sandro Santilli strk at kbt.io
Fri Feb 21 08:44:53 PST 2020
I'm struggling with a test that modifies a gpkg (only the header)
while QgsOgrProvider is NOT setting OGR_SQLITE_JOURNAL to WAL
(found with adding debugging to it).
Any idea about what else could be resulting in gpkg being open
in WAL mode, from a QgsServer request ?
A possible hint: modification of the file only happens when 2 GetMap
requests are made, by the same process (a single one of any of the
two requests does NOT result in modification).
Dragons are living here:
https://github.com/qgis/QGIS/pull/31980#issuecomment-589713595
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   https://strk.kbt.io/services.html
More information about the QGIS-Developer mailing list
