[QGIS-Developer] Build failed on Azure CI, how to get details
René-Luc Dhont rldhont at gmail.com
Wed Jan 15 06:29:04 PST 2020
Hi Dev,
My PRs https://github.com/qgis/QGIS/pull/33813 and
https://github.com/qgis/QGIS/pull/33725 failed to build on Azure CI.
The build log is minimalistic :
2020-01-15T10:12:39.7333036Z Build project
2020-01-15T10:12:39.7350985Z    Each symbol represents 1024 bytes of output.
2020-01-15T10:12:39.7351096Z    '!' represents an error and '*' a warning.
2020-01-15T10:21:19.1415558Z     .............................................*....  Size: 49K
2020-01-15T10:36:14.5224541Z     ..................*...............................  Size: 99K
2020-01-15T10:49:37.5635400Z     .......*****......................................  Size: 149K
2020-01-15T10:58:23.4653034Z     ....******........................................  Size: 199K
2020-01-15T11:07:34.3517006Z     .....*.......................*......**.......*** Size of output: 248K
2020-01-15T11:07:34.4586592Z Error(s) when building project
2020-01-15T11:07:34.4586766Z    1 Compiler errors
2020-01-15T11:07:34.4587572Z    56 Compiler warnings
2020-01-15T11:07:34.7983476Z [0/1] cmd.exe /C "cd /D D:\a\1\s\ms-windows\osgeo4w\build-qgis-dev-x86 && "C:\Program Files\CMake\bin\ctest.exe" -D ExperimentalSubmit"
2020-01-15T11:07:34.8127277Z    Site: azure-pipelines
2020-01-15T11:07:34.8127629Z    Build name: PR 33813 / master (1138) (d88e9cbd97) (qgis-dev Experimental x86)
2020-01-15T11:07:34.8147167Z Submit files
2020-01-15T11:07:34.8147322Z    Send to track: Experimental
2020-01-15T11:07:34.8147841Z    SubmitURL: https://cdash.orfeo-toolbox.org/submit.php?project=QGIS
2020-01-15T11:07:36.9734255Z    Uploaded: D:/a/1/s/ms-windows/osgeo4w/build-qgis-dev-x86/Testing/20200115-1012/Build.xml
2020-01-15T11:07:37.4788307Z    Uploaded: D:/a/1/s/ms-windows/osgeo4w/build-qgis-dev-x86/Testing/20200115-1012/Done.xml
2020-01-15T11:07:37.4789266Z    Submission successful
2020-01-15T11:07:37.4891009Z build failed
2020-01-15T11:07:37.4896897Z BUILD ERROR 0: Wed 01/15/2020 11:07:37.47
2020-01-15T11:07:37.9186422Z ##[error]Cmd.exe exited with code '1'.
2020-01-15T11:07:38.0958787Z ##[section]Finishing: Building QGIS
How to get details when the build failed ?
Thanks
René-Luc
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200115/ebfbf4d4/attachment.html>
More information about the QGIS-Developer mailing list
