[QGIS-Developer] [Qgis-user] Qgis crashes while loading WMTS layers
Jonathan Moules jonathan-lists at lightpear.com
Sun Jan 26 06:04:59 PST 2020
Hi Patrick,
I can't comment on the core issue, but just a point for clarification -
I thought Swap memory usage was something the operating system dealt
with? Isn't it usually transparent to the application?
A quick search indicates that what GIMP calls swap is really a bespoke
folder for GIMP to store temporary files (in a fashion similar to
virtual memory/swap) rather than the system swap file; FME does this too
(they call it a "temporary directory").
I can certainly see why that would have value - it looks like QGIS has
one, at least for temporary outputs -
https://github.com/qgis/QGIS/issues/28222 - but whether it's as well
used as it should be I leave for others to comment on (I have no idea
what it's used for).
Cheers,
Jonathan
On 2020-01-26 12:19, Patrick Dunford wrote:
> Good day to all.
> Not so long ago I wrote a post about issues handling large numbers of
> raster files. This results from what appears to be an architectural
> design limitation of Qgis in that it only has enough resources
> available for a certain (unknown) number of raster layers and does not
> have any effective system for dealing with the exhaustion of these
> resources.
> I also noted that the software does not appear to have the ability to
> use the swap (virtual memory) resources within a system to deal with
> the apparent exhaustion of resources, as other software would. For
> example, Gimp which I use for graphical editing is able to handle
> certain projects using a swap space of 200 GB, which consists of 32 GB
> of physical RAM and the rest in SSD. It is not unusual with some of
> these graphics projects to have 100 GB or more of swap space in use,
> without crashing the system. (This being possible since Gimp 2.10 with
> its ability to write files of more than 4 GB)
> Whilst it is possible to manage the number of layers with file based
> rasters, this cannot be done with a WMTS server because there is no
> way I am aware of to manage the number of layers that can be
> downloaded from the server.
> Version 2.18 and earlier almost never crashed with excess layers,
> usually all that would happen is a layer would be displayed with
> invalid data. However, crashes have become the norm with 3.x versions
> of software.
> It seems to me there is a big architectural problem in the software
> with its inability to utilise the full resources of the system in
> order to process the number of layers that a WMTS server is capable of
> issuing.
> Qgis-user mailing list
More information about the QGIS-Developer mailing list
