[QGIS-Developer] QGIS symbology: jumping point and line pattern fills
Alexandre Neto senhor.neto at gmail.com
Thu Jul 9 02:27:13 PDT 2020
Hi Andreas,
Try disabling Clip Features to canvas extent on the advanced combobox (next
to symbol levels)
I think it fix what you are seeing.
Alexandre Neto
A quinta, 9/07/2020, 10:17, Andreas Neumann <a.neumann at carto.net> escreveu:
> Hi,
> Working recently extensively with point and line pattern fills, I noticed
> that with each pan, the point and line pattern fills in QGIS kind of "jump"
> around relatively to their geometry, as if the offset of the pattern was
> kind of "random".
> You can see it in this video: https://www.youtube.com/watch?v=V4ytwM59_jY
> Is there any setting so I can avoid this behavior? Or could a QGIS dev
> with experience in symbology help fix this issue? I would assume if someone
> creates tiles from this, they would also run into issues at tile borders,
> because of this.
> Thanks if you have any ideas.
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200709/d033fd40/attachment.html>
More information about the QGIS-Developer mailing list
