[QGIS-Developer] QGIS server logs
Régis Haubourg regis.haubourg at gmail.com
Thu Jul 9 05:33:05 PDT 2020
Thanks Sylvain,
I tried -v /usr/bin/xdg-open:/usr/bin/xdg-open:ro with no success.
Bye
Le mer. 8 juil. 2020 à 14:26, Sylvain POULAIN <sylvain.poulain at giscan.com>
a écrit :
> @Regis,
> For xdg open and docker, just map your X11 running session inside docker
> container and export DISPLAY like this :
> -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=unix$DISPLAY
> It works with docker mundialis qgis 2. If not sufficient, you could map
> xdg-open to container :
> Why is it declared on the server version ?
> *Sylvain *
> <http://giscan.com>
> Le mer. 8 juil. 2020 à 12:19, Paolo Cavallini <cavallini at faunalia.it> a
> écrit :
>> Hi again,
>> on the same server I'm getting frequent:
>> [Wed Jul 08 10:15:21.847370 2020] [fcgid:warn] [pid 23438] [client
>> 127.0.0.1:37450] mod_fcgid: error reading data, FastCGI server closed
>> connection
>> [Wed Jul 08 10:15:21.847989 2020] [core:error] [pid 23438] [client
>> 127.0.0.1:37450] End of script output before headers: qgis_mapserv.fcgi
>> could this simply due to lack of resources (only 4Gb RAM) or there are
>> other explanations?
>> Cheers.
>> Il 06/07/20 20:16, Régis Haubourg ha scritto:
>> > Hi Paolo, I have those messages too when running QGIS desktop from a
>> > docker. Xdg-runtime is used to open default app for files or urls on the
>> > system. I think this has no impact on a server use case.
>> > But I wish I could forward this xdg commands to my host so that I can
>> > open help pages from QGIS in a docker :). If someone knows some magic
>> > here please share !
>> > Cheers
>> > Régis
>> > Le lun. 6 juil. 2020 à 18:29, Paolo Cavallini <cavallini at faunalia.it
>> > <mailto:cavallini at faunalia.it>> a écrit :
>> >     Hi all,
>> >     I'm getting some messages from the log file I do'nt understand[0]
>> >     I couldn't find an explanation in the manual. Does anybody have some
>> >     hints?
>> >     Thanks in advance.
>> >     [0]
>> >     Application path not initialized
>> >     QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to
>> >     '/tmp/runtime-www-data'
>> >     QNetworkDiskCache::prepare() unable to open temporary file
>> >     Paolo Cavallini
>> >     www.faunalia.eu <http://www.faunalia.eu> - QGIS.org
>> >     training, support, development on QGIS, PostGIS and more
>> >     _______________________________________________
>> >     QGIS-Developer mailing list
>> >     QGIS-Developer at lists.osgeo.org <mailto:
>> QGIS-Developer at lists.osgeo.org>
>> >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >     Unsubscribe:
>> Paolo Cavallini
>> www.faunalia.eu - QGIS.org
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200709/3fdfc4b1/attachment.html>
More information about the QGIS-Developer mailing list
