[QGIS-Developer] How to get animation_datetime()
Andreas Neumann
a.neumann at carto.net
Tue Jul 14 01:44:50 PDT 2020
Hi Nyall,
hm - but @animation_start_time and @animation_end_time seems not to be
moving along with the time slider. That remains "static" during the
animation.
Based on your feedback I was expecting @animation_start_time and
@animation_end_time to move along with the time slider - this doesn't
seem the case.
Anyway - with second(@frame_duration) * @frame_number
and this is also a single point in time, relative to the beginning of
the animation, not a "range" slice.
I get what I want (the current time representation value of the time
slider). I just thought there might be something "easier".
I might not get the full concept of the new temporal framework - I have
also to admit, that I didn't really use the TimeManager plugin a lot -
maybe with this background, things would have been clearer to me.
Thanks,
Andreas
Am 14.07.20 um 00:39 schrieb Nyall Dawson:
> On Tue, 14 Jul 2020 at 07:44, Andreas Neumann <a.neumann at carto.net> wrote:
>> animation_datetime() seems to be something from the old time manager plugin.
> Correct -- the new temporal framework works on the concept of a map
> having a time range, not a single time instant.
> The equivalent variables are:
> - @animation_start_time
> - @animation_end_time
> Nyall
>> Andreas
>> Am 13.07.20 um 23:25 schrieb Bernd Vogelgesang:
>>> Still not clear. Do you mean the timer running in the lower right?
>>> If so, see https://www.youtube.com/watch?v=vgDg5cRwPRw starting at 54:40
>>> for the formula
>>> On 13.07.20 23:14, Andreas Neumann wrote:
>>>> By "current time of an animation" I mean the current time represented
>>>> in the time slider control as a function or variable.
>>>> Thanks,
>>>> Andreas
>>>> Am 13.07.20 um 23:08 schrieb Andreas Neumann:
>>>>> Hi,
>>>>> In an animation (QGIS 3.14) - how do I get the current time of an
>>>>> animation?
>>>>> In https://www.youtube.com/watch?v=8R0TQlhdc1U&feature=youtu.be at
>>>>> minute 6:26, it shows a formula involving the "animation_datetime()"
>>>>> function.
>>>>> But my expression editor complains, that this function is not
>>>>> available.
>>>>> Thanks for your hints,
>>>>> Andreas
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200714/22db325a/attachment.html>
