[QGIS-Developer] qt and antialiasing - line pattern fills
    Andreas Neumann
    a.neumann at carto.net
    Wed Jul 22 00:39:48 PDT 2020
Hi Nyall,
Thanks for your reply.
Thanks for explaining the issue about the enforced rasterization of the
line pattern fills. Any rough estimate how much the speed penalty would
be when one would implement the line pattern fill purely as vector?
Also - would it be possible to "enforce" vector only rendering of line
and point pattern fills - not only for export, but also for server or
canvas rendering? As an example, when generating raster tiles, it would
be nice to get a higher quality (even on server output) at the expense
of speed. When a Mapproxy is harvesting tiles from a QGIS server, it
would be nice if there could be a parameter in the GetMap request that
enforces higher quality vector rendering at the expense of a lower
performance.
Thanks,
Andreas
On 2020-07-22 08:32, Nyall Dawson wrote:
> On Fri, 17 Jul 2020 at 19:34, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> In our efforts to improve cartographic quality, I'd also like to discuss, if we could somehow improve the quality of the line-pattern fills, and/or the antialiasing quality of the qt renderer. A very small change in angle can change the quality of a line-pattern fill in QGIS pretty or very ugly.
>> Also: even if all buildings in the following rendering have the same distance between lines, some look much "denser" than others. Have a look at the attached file where I labeled some line fills as ugly and pretty.
>> Is there something that QGIS could do to improve the "prettyness" of line pattern fills, or would this have to change in the qt library?
>> Thanks if you have any thoughts on this topic,
> Sorry for the delayed reply!
> This is a long-standing issue in QGIS' polygon fill support. See
> https://github.com/qgis/QGIS/issues/16100 (filed 2013). Basically, the
> line pattern symbol type uses a trick to speed up the rendering of
> features by first making a small tiled raster image of the line
> pattern, and then painting the polygons using this raster brush. It's
> nice and fast, and works well for canvas/server renders, but is far
> from ideal for high quality exports. It's also an issue if you try to
> use data defined settings on the line sub symbol -- because the
> pattern is generated using the tiled image, you won't see the expected
> results if you try to make the appearance of individual lines in the
> pattern vary.
> For reference, up until 3.14 the point pattern fill had the same
> limitation. For 3.14 point pattern fills were improved to now export
> the fill as vector markers (the same raster brush approach is still
> used for canvas renders, where speed is more important vs quality).
> What we need to do is implement a similar fix as was done for the
> point pattern fill, and render each individual line in a line pattern
> fill as a proper vector line (during layout exports, or when we detect
> that the line subsymbol has data defined properties set).  Hopefully
> something we can do for 3.16...
> Nyall
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200722/2b730440/attachment.html>
