[QGIS-Developer] SVG icons in QGIS
Nyall Dawson
nyall.dawson at gmail.com
Mon Jul 27 17:39:10 PDT 2020
On Mon, 27 Jul 2020 at 21:57, Jonathan Moules
<jonathan-lists at lightpear.com> wrote:
> Hi List,
> The more I look at the current SVG icons, the more I'm thinking it
> really needs some TLC (Tender Loving Care). As far as I can tell, icons
> are categorised by the directory they're in, so if you want an icon to
> appear in two categories, you put the icon in there twice... and so
> that's just what has happened! I suspect the current set has simply
> accreted over time.
For reference: I'm totally in agreement that we need to improve the
DEFAULT set of svg files, and that the resource sharing plugin isn't
the best solution here. It's a great solution for some use cases, but
we need to improve the out-of-the-box experience in this regard and
that means extending the default set.
> My thoughts:
> * Move the svg's into a single directory. (Though would break any
> current projects symbology using them I guess?)
Yes -- we CAN'T do this. What we've got now has to stay, in its
current structure, and without renaming.
> * Use a metadata file to categorise them, so you get a list of
> categories as now and a single symbol can be in multiple categories.
We could potentially add tags to the svg files themselves to add this
information.
> * Add a search feature so the user can quickly find "museum" without
> having to guess where it has been categorised.
Big +1 to this. Especially if we also add search by tag support!
> * Clean up the current symbols by removing duplicates.
Again, we can't do this without risking breaking people's existing
projects (which is off-limits!)
> * Add the font-awesome symbols (per my thread on the User List) to fill
> in the gaps and flesh out the collection. As a bonus, it comes with
> metadata for categories and search terms (YAML files).
> * bonus - metadata is internationalised so "museo" (IT), "muzeu" (RO),
> etc would also work for finding that museum.
> Thoughts?
Sounds good to me! To clarify -- are you volunteering to lead this effort?
Nyall
> Cheers,
> Jonathan
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
