[QGIS-Developer] Compiling in Windows 10 with Oracle support
Julien Cabieces julien.cabieces at oslandia.com
Tue Mar 3 23:32:20 PST 2020
It seems you don't have oracle instantclient (oci) installed in a
place where QGIS could find it.
If you take a look in CMakeCache.txt (in your build folder where there
is qgis.sln), you need to have this two lines correctly set
//Path to a file.
OCI_INCLUDE_DIR:PATH=C:/OSGeo4W64/include
//Path to a library.
OCI_LIBRARY:FILEPATH=C:/OSGeo4W64/lib/oci.lib
I think you need to install the two package oci and oci-devel with
OSGEO4W installer et restart package.cmd (or package-nightly.cmd).
Regards,
Julien
> Hello.
> I was able to build it in Visual Studio 2017 doing some changes at the
> scripts.
> However, I can't get any oracle support. The button is not present at the
> layer browser window and in DB Manager I get this error when try to connect
> to any oracle database:
> 2020-03-03T14:20:48     CRITICAL    Qt : QSqlDatabase: QOCISPATIAL
> driver not loaded
> 2020-03-03T14:20:48     CRITICAL    Qt : QSqlDatabase: available
> drivers: QSQLITE QMYSQL QMYSQL3 QODBC QODBC3 QPSQL QPSQL7
> There is also other erros on startup:
> 2020-03-03T17:33:58     WARNING    Falha ao carregar
> D:/workspace/github/QGIS/ms-windows/osgeo4w/build-qgis-test-x86_64/output/plugins/RelWithDebInfo/grassplugin7.dll
> (Razão: Cannot load library
> D:\workspace\github\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\output\plugins\RelWithDebInfo\grassplugin7.dll:
> Não foi possível encontrar o módulo especificado.)
> D:/workspace/github/QGIS/ms-windows/osgeo4w/build-qgis-test-x86_64/output/plugins/RelWithDebInfo/grassprovider7.dll
> D:\workspace\github\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\output\plugins\RelWithDebInfo\grassprovider7.dll:
> 2020-03-03T17:33:59     WARNING    Falha ao carregar
> D:/workspace/github/QGIS/ms-windows/osgeo4w/build-qgis-test-x86_64/output/plugins/RelWithDebInfo/grassrasterprovider7.dll
> D:\workspace\github\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\output\plugins\RelWithDebInfo\grassrasterprovider7.dll:
> D:/workspace/github/QGIS/ms-windows/osgeo4w/build-qgis-test-x86_64/output/plugins/RelWithDebInfo/qgisgrass7.dll
> D:\workspace\github\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\output\plugins\RelWithDebInfo\qgisgrass7.dll:
> 2020-03-03T17:33:59     WARNING    Erro Python : Impossível carregar
> complemento 'MetaSearch' Devido a um erro ao chamar o método Class
> Factory(). Consulte o registro de mensagens (Erro Python) para mais
> detalhes.
> 2020-03-03T17:33:59     WARNING    Complemento processing : O
> complemento será desabilitado porque ele fechou o QGIS durante seu
> último início. Por favor, reporte um erro e reabilite o complemento
> quando o problema estiver resolvido.
> 2020-03-03T17:33:59     CRITICAL    Qt : QString::arg: 9 argument(s)
> missing in O estado do aplicativo:
>              QGIS_PREFIX_PATH env var: ??% 1
>              Prefixo: ??% 2
>              Caminho do Complemento: ??% 3
>              Caminho de Dados Pacote: ?% 4
>              Ativo Theme Name: ?% 5
>              Caminho Tema ativo: ?% 6
>              Tema Padr�o Caminho: ?% 7
>              SVG caminhos de pesquisa: ?% 8
>              Usu�rio DB Path: ?% 9
>              Auth DB Path: ?% 10
> I used these
> <http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html>
> instructions.
> And also looked here
> <https://github.com/qgis/QGIS/blob/master/ms-windows/osgeo4w/package-nightly.cmd>.
> But no luck.
> Now I'm trying different oracle parameters when creating the vs solution.
> I don't have Oracle Client installed at my machine. But if you go to their
> website
> <https://www.oracle.com/database/technologies/instant-client/winx64-64-downloads.html>,
> you can see they now provide the OCI dlls without any installation at all.
> At my last attempt, I download the latest version and tried to generate the
> visual studio solution with the following parameters in *msvc-env.bat*:
> path %PATH%;D:\Ferramentas\oracle_instant_client\instantclient_19_5
> set OCI_INCLUDEDIR=D:\Ferramentas\oracle_instant_client\instantclient_19_5
> set OCI_INCDIR=D:\Ferramentas\oracle_instant_client\instantclient_19_5
> set OCI_LIBDIR=D:\Ferramentas\oracle_instant_client\instantclient_19_5
> set ORACLE_HOME=D:\Ferramentas\oracle_instant_client\instantclient_19_5
> set ORACLE_INCLUDEDIR=D:\Ferramentas\oracle_instant_client\instantclient_19_5
> set ORACLE_LIBDIR=D:\Ferramentas\oracle_instant_client\instantclient_19_5
> Also in *qgis\CMakeList.txt* I did this edit:
> IF(WITH_ORACLE)
>     SET(HAVE_ORACLE TRUE)
>     SET(ORACLE_INCLUDEDIR ${ORACLE_INCLUDEDIR} CACHE STRING "Path to
> OCI headers")
>     SET(ORACLE_LIBDIR ${ORACLE_LIBDIR} CACHE STRING "Path to OCI libraries")
>   ENDIF(WITH_ORACLE)
> To be able to compile and run the program in visual studio, I had to copy
> all qt5 dlls, proj_7_1.dll and gdal301.dll to the output diretocry.
> I also noticed that \OSGeo4W\apps\Qt5\plugins\sqldrivers does not have the
> OCI driver.
> Anyway, can someone point me exactly what I have to do to build qgis in
> windows with oracle support? I need to fix this issue
> <https://github.com/qgis/QGIS/issues/24539>
> Thanks
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
