[QGIS-Developer] Fwd: Compiling Problem QGis 3.12.1 on CentOS 7.6
Victor LOPES piaff33z at gmail.com
Wed Mar 25 03:33:54 PDT 2020
Hello is someone can help with this case ?
Vic
Le 24/03/2020 à 17:42, piaff33z a écrit :
> Hello all, I need some help to compile and install last version of
> QGis 3.12.1 :-)
> Below my explanation about my last last blocking point.
> Context :
> My system is an CentOS Linux release 7.6.1810 (Core) on Linux
> 3.10.0-957.10.1.el7.x86_64 #1 SMP
> Making tools
> Provide by CentOS :
> gcc-c++-4.8.5-39.el7.x86_64
> libgcc-4.8.5-39.el7.x86_64
> Devtoolset installed if some products need to be compiled with more
> recent compiler :
> devtoolset-7-gcc-7.3.1-5.16.el7.x86_64
> devtoolset-7-gcc-c++-7.3.1-5.16.el7.x86_64
> I compiled successfully software below to have last versions
> lrwxrwxrwx. 1 root root    11 23 mars  15:15 gdal -> gdal-3.0.4/
> drwxr-xr-x. 7 root root  4096 23 mars  15:15 gdal-3.0.4
> lrwxrwxrwx. 1 root root    11 23 mars  15:52 grass -> grass-7.8.2
> drwxr-xr-x. 4 root root  4096 23 mars  15:57 grass-7.8.2
> lrwxrwxrwx. 1 root root    19 23 mars  17:11 libspatialite ->
> libspatialite-4.3.0
> drwxr-xr-x. 4 root root  4096 23 mars  17:11 libspatialite-4.3.0
> drwx------. 2 root root 16384 21 mars   2019 lost+found
> lrwxrwxrwx. 1 root root    10 23 mars  17:23 proj -> proj-4.9.3
> drwxr-xr-x. 6 root root  4096 23 mars  17:23 proj-4.9.3 ( I tried with
> proj-7.0.0 but is too recent for QGis 3.12.1 :-( )
> lrwxrwxrwx. 1 root root    11 23 mars  14:05 sqlite -> sqlite-3.32
> drwxr-xr-x. 6 root root  4096 23 mars  14:05 sqlite-3.32
> Qt5 is provide by my distribution and I didn't try to compile it from
> source
> qca-qt5-2.1.3-3.el7.x86_64
> qt5-qttools-common-5.9.7-1.el7.noarch
> qt5-qtwebkit-devel-5.9.1-2.el7.x86_64
> qt5-qtwayland-devel-5.9.7-1.el7.x86_64
> qt5-qtbase-gui-5.9.7-2.el7.x86_64
> qt5-qtlocation-5.9.7-1.el7.x86_64
> python36-qt5-webkit-5.12.1-3.el7.x86_64
> qt5-qtgraphicaleffects-5.9.7-1.el7.x86_64
> qt5-qtquickcontrols2-devel-5.9.7-1.el7.x86_64
> qt5-qtstyleplugins-5.0.0-29.el7.x86_64
> qt5-qtbase-odbc-5.9.7-2.el7.x86_64
> qt5-qtserialport-5.9.7-1.el7.x86_64
> qt5-qtenginio-1.6.2-2.el7.x86_64
> qt5-qttools-devel-5.9.7-1.el7.x86_64
> qt5-qtaccountsservice-devel-0.1.1-3.el7.x86_64
> qt5-qtenginio-devel-1.6.2-2.el7.x86_64
> qca-qt5-gnupg-2.1.3-3.el7.x86_64
> qca-qt5-devel-2.1.3-3.el7.x86_64
> qt5-qtwebkit-5.9.1-2.el7.x86_64
> qt5-qttools-5.9.7-1.el7.x86_64
> qt5-qtimageformats-5.9.7-1.el7.x86_64
> qt5ct-0.35-2.el7.x86_64
> qt5-qtx11extras-5.9.7-1.el7.x86_64
> qt5-qtdeclarative-5.9.7-1.el7.x86_64
> qt5-qtmultimedia-5.9.7-1.el7.x86_64
> python36-qt5-5.12.1-3.el7.x86_64
> qt5-linguist-5.9.7-1.el7.x86_64
> qt5-qtconfiguration-0.3.0-3.el7.x86_64
> qt5-qt3d-5.9.7-1.el7.x86_64
> qt5-qtquick1-devel-5.7.1-2.2bc722agit.el7.x86_64
> qt5-qtwebchannel-devel-5.9.7-1.el7.x86_64
> qt5-qtdeclarative-static-5.9.7-1.el7.x86_64
> qca-qt5-pkcs11-2.1.3-3.el7.x86_64
> qca-qt5-nss-2.1.3-3.el7.x86_64
> qt5-rpm-macros-5.9.7-2.el7.noarch
> qt5-qtserialport-devel-5.9.7-1.el7.x86_64
> qt5-qttools-libs-help-5.9.7-1.el7.x86_64
> qt5-qtwebsockets-5.9.7-1.el7.x86_64
> qt5-qttools-libs-designercomponents-5.9.7-1.el7.x86_64
> qt5-qtscript-devel-5.9.7-1.el7.x86_64
> qt5-qtcanvas3d-5.9.7-1.el7.x86_64
> qt5-qdbusviewer-5.9.7-1.el7.x86_64
> qt5-qtbase-static-5.9.7-2.el7.x86_64
> qt5-qtsensors-devel-5.9.7-1.el7.x86_64
> qca-qt5-cyrus-sasl-2.1.3-3.el7.x86_64
> qt5-qtbase-devel-5.9.7-2.el7.x86_64
> qt5-qtsvg-devel-5.9.7-1.el7.x86_64
> qt5-qttools-libs-designer-5.9.7-1.el7.x86_64
> qt5-designer-5.9.7-1.el7.x86_64
> qt5-qtquick1-5.7.1-2.2bc722agit.el7.x86_64
> qt5-qtquickcontrols-5.9.7-1.el7.x86_64
> qt5-qtbase-mysql-5.9.7-2.el7.x86_64
> qt5-qtbase-postgresql-5.9.7-2.el7.x86_64
> qca-qt5-softstore-2.1.3-3.el7.x86_64
> qt5-qtbase-common-5.9.7-2.el7.noarch
> qt5-qtserialbus-5.9.7-1.el7.x86_64
> qt5-qtwebchannel-5.9.7-1.el7.x86_64
> python-qt5-rpm-macros-5.12.1-3.el7.noarch
> qt5-qtlocation-devel-5.9.7-1.el7.x86_64
> qt5-qtx11extras-devel-5.9.7-1.el7.x86_64
> qt5-qtxmlpatterns-devel-5.9.7-1.el7.x86_64
> qt5-qt3d-devel-5.9.7-1.el7.x86_64
> qt5-qtwebsockets-devel-5.9.7-1.el7.x86_64
> qca-qt5-gcrypt-2.1.3-3.el7.x86_64
> qt5-qtserialbus-devel-5.9.7-1.el7.x86_64
> python36-pyqt5-sip-4.19.16-3.el7.x86_64
> qt5-qtscript-5.9.7-1.el7.x86_64
> qt5-qtconnectivity-devel-5.9.7-1.el7.x86_64
> qca-qt5-logger-2.1.3-3.el7.x86_64
> qt5-qtsvg-5.9.7-1.el7.x86_64
> qt5-qtconnectivity-5.9.7-1.el7.x86_64
> qt5-doctools-5.9.7-1.el7.x86_64
> qt5-qtaccountsservice-0.1.1-3.el7.x86_64
> qt5-assistant-5.9.7-1.el7.x86_64
> qca-qt5-botan-2.1.3-3.el7.x86_64
> qca-qt5-ossl-2.1.3-3.el7.x86_64
> qt5-qtbase-5.9.7-2.el7.x86_64
> qt5-qtsensors-5.9.7-1.el7.x86_64
> qt5-qtdeclarative-devel-5.9.7-1.el7.x86_64
> qt5-qtquickcontrols2-5.9.7-1.el7.x86_64
> qt5-qtconfiguration-devel-0.3.0-3.el7.x86_64
> qt5-qtxmlpatterns-5.9.7-1.el7.x86_64
> python36-qt5-base-5.12.1-3.el7.x86_64
> qt5-qtwayland-5.9.7-1.el7.x86_64
> qt5-qtmultimedia-devel-5.9.7-1.el7.x86_64
> qt5-qttools-static-5.9.7-1.el7.x86_64
> Result after compiliing with cmake3 --version
> cmake3 version 3.14.6
> [root at build-master]# cmake3 .. -DGDAL_LIBRARY=/opt/gdal/lib
> -DPROJ_LIBRARY=/opt/proj/lib -DPROJ_INCLUDE_DIR=/opt/proj/include
> -DSQLITE3_INCLUDE_DIR=/opt/sqlite/include
> -DSQLITE3_LIBRARY=/opt/sqlite/lib
> -DGRASS_INCLUDE_DIR=/opt/grass/include -DGRASS_LIBRARY=/opt/grass/lib
> -- QGIS version: 3.12.1 București (31201)
> -- Found OpenCL C++ headers: /usr/include
> *-- Could not find GRASS 7*
> -- Found Proj: /opt/proj/lib version 4 (4.9.3)
> -- Found GEOS: /usr/lib64/libgeos_c.so (3.4.2)
> -- Found GDAL: /opt/gdal/lib (3.0.4)
> -- Found Expat: /lib64/libexpat.so
> -- Found Qwt: /usr/lib64/libqwt.so (6.1.1)
> -- Found libzip: /usr/lib64/libzip.so
> -- Found Sqlite3: /opt/sqlite/lib
> -- Found PostgreSQL: /usr/lib64/libpq.so
> -- Qt WebKit support enabled
> -- Found Qt version: 5.9.7
> -- Found QScintilla2: /usr/lib64/libqscintilla2.so (2.8)
> -- Found QCA: /usr/lib64/libqca-qt5.so (2.0.3)
> -- QCA OpenSSL plugin C++ check failed to compile
> -- QCA OpenSSL plugin C++ check compile output:
> -- Change Dir:
> /images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp
> Run Build Command(s):/usr/bin/gmake cmTC_2370e/fast
> /usr/bin/gmake -f CMakeFiles/cmTC_2370e.dir/build.make
> gmake[1] : on entre dans le répertoire «
> /images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp »
> Building CXX object CMakeFiles/cmTC_2370e.dir/qcaossl.cpp.o
> /usr/bin/c++   -I/usr/include/qt5 -I/usr/include/qt5/QtCore
> -I/usr/lib64/qt5/./mkspecs/linux-g++ -I/usr/include/QtCrypto  -fPIC
> -std=gnu++11 -o CMakeFiles/cmTC_2370e.dir/qcaossl.cpp.o -c
> /images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp/qcaossl.cpp
> In file included from /usr/include/QtCrypto/qca.h:38:0,
>                  from /usr/include/QtCrypto/QtCrypto:1,
>                  from
> /images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeTmp/qcaossl.cpp:2:
> /usr/include/QtCrypto/qca_basic.h:318:14: erreur: ‘QIODevice’ has not
> been declared
>   void update(QIODevice *file);
> gmake[1]: *** [CMakeFiles/cmTC_2370e.dir/qcaossl.cpp.o] Erreur 1
> gmake[1] : on quitte le répertoire «
> gmake: *** [cmTC_2370e/fast] Erreur 2
> CMake Error at cmake/QCAMacros.cmake:76 (message):
>   QCA OpenSSL plugin not found (run-time/unit-test dependency)
> Call Stack (most recent call first):
>   CMakeLists.txt:444 (FIND_QCAOSSL_PLUGIN_CPP)
> -- Configuring incomplete, errors occurred!
> See also
> "/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeOutput.log".
> See also
> "/images/compile/QGIS-final-3_12_1/build-master/CMakeFiles/CMakeError.log".
> Two problems :
>   * What are the variables to tell where is Grass 7 path installation
>     for my cmake3 call ?
>     Is not clearly defined in ../cmake/FindGRASS.cmake like others
>     cmake files ?
>   * Could someone help me to understand what is missing in my system
>     or compile parameters :-)
> I can post CMakeOutput.log or CMakeError.log, but i don't be sure that
> this mailing accept this type of sending...
> Vic
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200325/655d2ad5/attachment.html>
More information about the QGIS-Developer mailing list
