[QGIS-Developer] GeoPackage - where are we -where do we go
Andreas Neumann a.neumann at carto.net
Fri May 8 04:32:12 PDT 2020
Very well. I am glad we are at the same boat here ;-)
Andreas
Am 08.05.20 um 12:43 schrieb Matthias Kuhn:
> Hi Andreas
> Thanks for also pointing out this question. I would like to completely
> focus on b) for now to not disperse the discussion too much.
> If it comes down to unresolvable problems we can still go for d).
> But let's keep that for later.
> Matthias
> On 5/8/20 11:59 AM, Andreas Neumann wrote:
>> Hi Matthias,
>> Thank you for listing all the open issues/problem with gpkg that you
>> know of. It really helps.
>> If we don't like gpkg as default format - the question is: what is
>> the alternative?
>> a) stay with ESRI shapefile (I think noone would like this)
>> b) work with the SQLite, gpkg/OGC community to fix the gpkg issues
>> (my preference)
>> c) use ESRI FGDB format (then we are at the mercy of ESRI)
>> d) invent something new (risky, if only QGIS uses that,
>> interoperability would suck)
>> I would prefer option b) a lot, and if that is not feasible, then
>> maybe d). d) will also be risky.
>> a) would equally suck as the current state of gpkg - I've seen far
>> too many corrupt shape files, people complaining about
>> interoperability issues (ArcGIS would show features that had been
>> deleted in QGIS, ) and I don't need to repeat the list of the
>> numerous restrictions of ESRI shp format.
>> Andreas
>> Am 08.05.20 um 11:30 schrieb Matthias Kuhn:
>>> Hi list,
>>> I wondered about the state of GeoPackage. Personally, cince it has
>>> been introduced to qgis and evenmore since it has been selected as
>>> the default format, I have never grown to fully and completely.
>>> I do not want to trigger a evangelical discussion here. I'd like to
>>> see where we are and what we can reasonably do to have a default
>>> file format which can be recommended with no bad feelings.
>>> Here follow a couple of observations over the years, some of them
>>> properties of the specs I believe:
>>> * The fid requirement
>>>   I sometimes want my features to be identified by uuids or others.
>>> They also tend to accumulate if derived datasets are created
>>> (through processing etc). If I need some pseudo stable primary key
>>> there is a rowid builtin into sqlite, we don't need a second one.
>>>   Possible mitigation: alter the ogr implementation. possibly alter
>>> the standard (required?)
>>> * The modification on r/o open
>>>   Has caused too much pain on git.
>>>   Possible mitigation: a) switch to journal mode=delete (not an easy
>>> option because of https://issues.qgis.org/issues/15351) b) only
>>> switch to wal mode when layers are put into edit mode (I have strong
>>> doubts this is a safe thing to do)
>>> * The network share freeze
>>>   Our default file should play nicely with (windows) network shares.
>>> It's clear to everyone that we can't expect concurrent writes. But
>>> it should "just work" for concurrent read by many.
>>>   Possible mitigation: switch to journal mode=delete for network
>>> shares (we are looking into this)
>>> * The wal file appearing next to the file
>>>   It is confusing to newcomers and looks almost like a sidecar file.
>>> I would care less if it was put into some system cache folder
>>> instead of just into my data folder. Or at least if it was a hidden
>>> file.
>>>   Possible mitigation: switch to journal mode=delete (not an easy
>>> * The couple of corrupted files I have received over the years which
>>> could only be repaired by a command line "dump contents as sql and
>>> execute into new file"
>>>   I have not found a way to reproduce this. Some of them were
>>> produced by older qgis versions making it easy to violate foreign
>>> key constraints and hard to recover. This has been fixed.
>>>   Possible mitigation: offer a "repair" option in qgis. Through
>>> processing or "on the fly" upon detection.
>>> *Default value magic replace values on insert (with no possibility
>>> to pre-evaluate them)
>>>   E.g. a global sequence like on postgres would be nice. Can be
>>> worked around through default values in qgis though.
>>>   Possible mitigation: a)add it as a feature to sqlite. b) use qgis
>>> default values. c) live with it.
>>> *The requirement for a single geometry column per table
>>>   I just don't see a good reason to forbid that
>>>   Possible mitigation: a) alter the standard. b) ignore the standard
>>> and patch the ogr implementation.
>>> I wonder how others feel about these topics.
>>> - Are there more pain points I forgot to list?
>>> - Do you see more approaches to mitigate these problems?
>>> - Is someone already working on these issues?
>>> It would be great to have a standard file format that we can fully
>>> trust. Let's make a reality check if GeoPackage can be this format.
>>> Best regards
>>> Matthias Kuhn
>>> matthias at opengis.ch <mailto:matthias at opengis.ch>
>>> +41 (0)76 435 67 63 <tel:+41764356763>
>>> OPENGIS.ch Logo <http://www.opengis.ch>
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200508/40b386f9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200508/40b386f9/attachment-0001.png>
More information about the QGIS-Developer mailing list
