[QGIS-Developer] QGIS Server now install a full DE?
Henrik Larsson kartogishenko at gmail.com
Thu May 14 11:04:59 PDT 2020
When installing QGis Server on Windows using the OSGeo4W installer its
actually the only way. Trying to install only the server part and you
will not get all dll:s to run the application. Desktop is needed.
best regards // Henrik
Den 2020-05-14 kl. 15:31, skrev Sebastiaan Couwenberg:
> On 5/14/20 3:24 PM, Giovanni Manghi wrote:
>> I noticed that the list of dependencies to be installed was weirdly very
>> long, and in fact after finishing it was also installed Gnome... is this
>> normal now?
> It is when you install Recommends, which now enabled by default.
>> here is the list of packages installed when doing sudo apt-get install
>> qgis-server:
> The list is shorter when using:
>   apt install --no-install-recommends qgis-server
> Kind Regards,
> Bas
More information about the QGIS-Developer mailing list
