[QGIS-Developer] Globe Plugin
Marco Bernasocchi marco at opengis.ch
Wed May 20 00:14:03 PDT 2020
As one of the grandfathers of the original Globe plugin, I'd say ditch
it - BUT... let's see what Matthias,  Martin and  Sandro think since
they probably are the ones that are most up-to-date on can now be done
with the 3d map canvas and globe
Cheers
Marco
On 19.05.20 22:03, José de Paula Rodrigues wrote:
> Hi all,
> I've taken a shot at building qgis with the globe plugin enabled on a
> current Gentoo. I've found that the plugin must be built against
> osgearth no newer than version 2.8 (which was released 2016-09-15),
> because newer versions remove features needed by Globe (osgearth 2.9,
> released 2018-02-07, removes the osgEarthUtilModule, and osgearth
> 2.10.1 - which is the latest release, from 2019-04-19, removes Qt
> support altogether).
> So, I find that the plugin is unbuildable on a modern system, unless
> it drops the need for the osgearth library. Should it be kept in the
> qgis tree even so?
Marco Bernasocchi
OPENGIS.ch CEO
QGIS.org Chair
marco at opengis.ch <mailto:marco at opengis.ch>
+41 (0)79 467 24 70 <tel:+41794672470>
OPENGIS.ch Logo <https://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200520/4e0577ce/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200520/4e0577ce/attachment.png>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200520/4e0577ce/attachment.sig>
More information about the QGIS-Developer mailing list
