[QGIS-Developer] Processing: sort algorithm not working?
Arnaud Morvan arnaud.morvan at camptocamp.com
Mon Nov 23 08:58:58 PST 2020
Hi Andreas.
Note that the order of features in attributes table does not seems to
reflect the source order.
After sorting your dataset with sortbyexpression, try to add a
auto-incremental field and open this new output in attribute table.
Sort this attribute table by the new auto-incremental field. If the
order is good, it is not a sortbyexpression issue, but an attribute
table issue.
Regards
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
18 rue du Lac Saint André
Savoie Technolac - Bâtiment Le Dauphin
F-73370 Le Bourget du Lac
http://www.camptocamp.com
Le 21/11/2020 à 17:23, Bernd Vogelgesang a écrit :
> Hi Andreas,
> have a look at my last years issue on this
> https://github.com/qgis/QGIS/issues/29794
> maybe it's the same
> Cheers,
> Bernd
> On 19.11.20 14:16, Andreas Neumann wrote:
>> Hi,
>> I have a model where at the very end before adding it to the project I was
>> trying to sort the result with an expression.
>> But: the sorting doesn't work. In the help there is the cryptic hint at
>> https://docs.qgis.org/3.10/de/docs/user_manual/processing_algs/qgis/vectorgeneral.html#qgisorderbyexpression
>> that "Be careful, it might not work as expected with some providers, the
>> order might not be kept every time."
>> Does someone know more about it? Which providers specifically do not
>> support sorting?
>> Does this statement apply to the reading provider or the writing provider?
>> In my case, I never got any correct sorting ...
>> Thanks,
>> Andreas
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201123/8ab10c50/attachment.html>
More information about the QGIS-Developer mailing list
