[QGIS-Developer] Tests failing with PostgreSQL 12/PostGIS 3.0
    José de Paula Rodrigues
    espinafre at gmail.com
    Tue Sep 29 06:42:01 PDT 2020
Hi all,
I've tried running some test cases locally against PostgreSQL 12 and
PostGIS 3.0.0 ~ 3.0.2. These tests are consistently failing here,
whereas they run successfully on Travis. Attached are the logs of
running
ctest --progress --output-on-failure -R '(PyQgsPostgresProvider)'
against the latest master commit
(a0ec11948b561029b5d838dee89dc7ea4c8d115b, 2020-09-29 08:52+0200),
with QGIS_DEBUG=5 environment variable. The file unpacks to a 18M
plaintext log.
The failure found on line 167545 doesn't bother me much, it looks like
a rounding error which can be easily corrected by applying round() to
both sides of the test comparison.
What worries me is the failure reported on line 167554. From what I
could figure, it comes from the SQL statement printed on line 17136:
DECLARE qgis_745 BINARY CURSOR FOR SELECT
st_asbinary("geom",'NDR'),ctid,"pk"::text FROM
"qgis_test"."some_poly_data" WHERE
ST_Overlaps(ST_Buffer("geom",1,'8'),ST_GeomFromText('Polygon ((-75.1
76.1, -75.1 81.6, -68.8 81.6, -68.8 76.1, -75.1 76.1))',4326))
This makes the database report the following error: "Missing value for
buffer parameter 8"
As I said, however, these tests run flawlessly on Travis, and they
used to run flawlessly on my local PostgreSQL 12/PostGIS 3.0.2
environment; I'm at a loss to pinpoint what changed, and maybe this is
one more reason to upgrade the CI to test against newer PostgreSQL
versions.
Thank you very much for any insights!
... et cognoscetis veritatem et veritas liberabit vos.
Type: application/gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200929/bbf0e5e8/attachment-0002.gz>
