[QGIS-Developer] QGIS + Cluster PostgreSQL
Tim Sutton tim at kartoza.com
Sat Apr 24 03:14:20 PDT 2021
Though I guess through service files you could present the RW database to the editor roles and the RO database to the analyst roles. That way you would not need duplicate layers.
Regards
Tim
Sent from my iPhone
> On 24 Apr 2021, at 09:21, Bo Victor Thomsen <bo.victor.thomsen at gmail.com> wrote:
> If I understand the situation correctly:
> You have a main database with access on port 5432 with replication to another database with access on port 5433. Both databases on the same server ??
> The main database gives a set of users read/write access the the main database
> The replication database gives (another) set of users read-only access to data.
> I've used the same setup in some cases: You have a small number of editing users with read/write access to tables on a "small" main database server. The data is then replicated to a larger database server where a large number of users have read-only access to the data.
> The small "main" database server is optimised for editing purposes. And the secondary database-server is optimised for analytical purposes. The performance of the "main" server will never be degraded by the - perhaps excessive - use from the read-only user group. The replication can even be delayed to times where the number of database users is minimal
> However, The scenario makes only sense if the 2 databases is placed on 2 different database servers.
> Your question: The answer is yes, QGIS supports access to Postgres databases through different ports. However, for the QGIS user it would look like 2 different layers, one with read/write access to data and another layer with read-only access to the data. The 2 layers will contain the "same data" (Depending on how the replication is set up). That's because you have to define 2 different Data Sources, one for each database
> It would make more sense to have 2 QGIS projects: A "editing" project with one read/write layer (access to the main database) and another QGIS project with one read-only layer (access to the replication database).
> Med venlig hilsen / Kind regards
> Bo Victor Thomsen
> Den 22-04-2021 kl. 20:08 skrev Rebassa Oliver, Joan:
>> Buenas tardes:
>> Tenemos configurado un cluster de base de datos de PostgreSQL de forma que el nodo maestro de este cluster es el que permite las operaciones de escritura en base de datos a través del puerto 5432 y el resto de nodos que forman el cluster son nodos esclavos a los que se replican los cambios que se han hecho en el maestro y asumen las operaciones de lectura en base de datos por el puerto 5433, las aplicaciones que han de acceder a las bases de datos deben poder tener definidos dos datasources: uno para las operaciones de escritura por el puerto 5432 y otro para lectura por el puerto 5433, queremos saber si Qgis soporta esta configuración.
>> Gracias.
>> Good afternoon:
>> We have configured a PostgreSQL database cluster so that the master node of this cluster is the one that allows database write operations through port 5432 and the rest of the nodes are slave nodes, the changes that have been made in the master are replicated to the slave nodes and they assume the database read operations through port 5433, the applications that have to access the databases must have two datasources configured: one for database write operations (port 5432) and another for read operartions (port 5433), we want to know if Qgis supports this configuration.
>> Thanks.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210424/fff79c8d/attachment-0001.html>
More information about the QGIS-Developer mailing list
