[QGIS-Developer] Grant report: Integrate GPS Tools plugin functionality into core QGIS
Andreas Neumann a.neumann at carto.net
Thu Aug 5 07:47:28 PDT 2021
+1 - if it would be possible to remove the qwtpolar dependency (but
apprently not part of this grant).
I remember I had troubles in the past because qwtpolar dependencies.
Andreas
On 2021-08-05 16:37, Jürgen E. Fischer wrote:
> Hi,
> On Thu, 05. Aug 2021 at 09:56:49 +1000, Nyall Dawson wrote:
>> - GPS Information panel: this is the live/interactive view of a GPS
>> connection, and is responsible for showing the current position on the
>> GPS and tracking it. It's been relatively well maintained over the
>> years, and while it could do with some UI modernization the code
>> behind it is all quite stable and mature.
> Which reminds me that the info panel is the only part that depends on
> qwtpolar.
> So a potential UI modernization might also remove
> external/qwtpolar-1.1.1/,
> which we have just for this.
> Jürgen
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210805/b3c4f846/attachment.html>
More information about the QGIS-Developer mailing list
