[QGIS-Developer] pyqgis getFeatures(<FilterExpression>) doesn't always fetch modified geometry
Matthias Kuhn
matthias at opengis.ch
Sat Dec 11 23:23:51 PST 2021
Hi
I could replicate it here and can confirm it is a bug and commitChanges() a
functional band aid for scripts.
Can you open an issue on github including this testcase?
Thanks
Matthias
On Sun, Dec 12, 2021 at 8:07 AM Ujaval Gandhi <ujaval at spatialthoughts.com>
wrote:
> Try calling layer.commitChanges() after changing the geometry.
> [image: Logo] <https://spatialthoughts.com/>
> Ujaval Gandhi
> Spatial Thoughts
> mobile: +91-8095684687
> email: ujaval at spatialthoughts.com
> [image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
> Twitter icon] <https://twitter.com/spatialthoughts>
> On Sat, Dec 11, 2021 at 6:55 PM Erik Polzin <eriktpol at gmail.com> wrote:
>> Hi all,
>> Noticed some strange behaviour in QGIS' Python API the other day.
>> I needed to get a subset of points from a memory layer of point features,
>> and had previously done so by calling getFeatures(), and then filtering
>> this iterable in Python. I thought I could speed it up by using a filter
>> expression directly to let c++ do the filtering instead, but was surprised
>> to see that now the geometry wasn't up to date with the memory layer's edit
>> buffer.
>> I've replicated the behaviour it in a small script here:
>> from qgis.core import QgsVectorLayer, QgsField, QgsGeometry, QgsPointXY,
>> QgsFeature
>> from PyQt5.QtCore import QVariant
>> layer = QgsVectorLayer("Point", "test", "memory")
>> pr = layer.dataProvider()
>> pr.addAttributes([QgsField("name", QVariant.String)])
>> layer.updateFields()
>> initialGeom = QgsGeometry.fromPointXY(QgsPointXY(0, 0))
>> f = QgsFeature()
>> f.setGeometry(initialGeom)
>> f.setAttributes(["Tom"])
>> added, (f,) = layer.dataProvider().addFeatures([f])
>> layer.startEditing()
>> editedGeom = QgsGeometry.fromPointXY(QgsPointXY(1, 1))
>> layer.changeGeometry(f.id(), editedGeom)
>> layer.changeAttributeValues(f.id(), {0: "Harry"})
>> for f in layer.getFeatures():
>> print(f.id(), f.attributes(), f.geometry())
>> for f in layer.getFeatures("name = 'Harry'"):
>> # >>> Prints different results!
>> This only seems to happen with both calls to changeGeometry and
>> changeAttributeValues.
>> Is there some way of getting around this? Would it be classified as a bug
>> in the API?
>> Cheers,
>> Erik
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211212/4a3a0244/attachment.html>
