[QGIS-Developer] QGIS (release-3_22) compilation
rnathreddy at sanasw.com rnathreddy at sanasw.com
Sun Dec 12 17:31:21 PST 2021
Trying to compile the qgis (release-3_22 branch) with MSVC 2015 on Windows
10 (64 bit version).
When I run the configonly.bat file I am getting the following errors:
E:\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\CMakeFiles\CMakeTmp\src.cx
x(1): error C2065: '__deprecated__': undeclared identifier
[E:\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\CMakeFiles\CMakeTmp\cmTC_
7bce4.vcxproj]
x(1): error C4430: missing type specifier - int assumed. Note: C++ does not
support default-int
7bce4.vcxproj]
x(1): error C2448: '__attribute__': function-style initializer appears to be
a function definition
7bce4.vcxproj]
Done Building Project
"E:\QGIS\ms-windows\osgeo4w\build-qgis-test-x86_64\CMakeFiles\CMakeTmp\cmTC_
7bce4.vcxproj" (default targets) -- FAILED.
The CMake error log is also attached.
Can anyone help me in this regard?
Regards
Raghunath
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211213/3376f0de/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211213/3376f0de/attachment.obj>
More information about the QGIS-Developer mailing list
