[QGIS-Developer] Issue with future 3.22 LTR ? (a.k.a missing backports to 3.22)
Olivier Dalang olivier.dalang at gmail.com
Tue Dec 14 05:48:46 PST 2021
Ok, well that's reassuring :-)
Thanks for the clarifications !
Cheers,
Olivier
Le ven. 10 déc. 2021 à 09:09, Etienne Trimaille <etienne.trimaille at gmail.com>
a écrit :
> As Harissou said, the PR was created before the 3.22 branch, so the label
> "backport release-3_32" was not created at that time.
> Le jeu. 9 déc. 2021 à 15:54, DelazJ <delazj at gmail.com> a écrit :
>> Hi Olivier,
>> Yes, backporting to 3.16 implies backport to 3.22. And I think the PR you
>> point here is more about forgetting. The PR itself is opened during 3.22.0
>> dev cycle and merged few days after release, so easier to forget to add the
>> label.
>> And the list of missing PRs should actually be
>> https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+queued_ltr_backports%22+-label%3A%22backport+release-3_22%22+merged%3A%3E2021-10-21
>> since anything merged before 22/10/2021 is automatically in 3.22. Finally,
>> there's no that much leftover PRs, so I think everybody is OK with your
>> logic.
>> Regards,
>> Harrissou
>> Le jeu. 9 déc. 2021 à 15:29, Olivier Dalang <olivier.dalang at gmail.com> a
>> écrit :
>>> Hi all !
>>> There's something I don't completely understand with the current
>>> branches/releases process and which to me looks like a major issue (came
>>> across it while checking the status of a recently merged bugfix PR#45521
>>> <https://github.com/qgis/QGIS/pull/45521>).
>>> That fix was merged to master with the `backport queued_ltr_backports`
>>> label, but without `backport release-3_22`.
>>> As far as I understand, this means it will be available in 3.24 (master)
>>> and in 3.16 (after some quarantine), but not in 3.22. Still if I understand
>>> correctly, 3.22 is our future LTR, meaning that LTR users will at some
>>> point upgrade from 3.16 to 3.22. Does that mean that the bug they have seen
>>> fixed in 3.16 will be reintroduced in 3.22 ?
>>> The following filter shows many other PRs backported to 3.16 but not
>>> 3.22 :
>>> is:pr label:"backport queued_ltr_backports" -label:"backport
>>> release-3_22"
>>> <https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+queued_ltr_backports%22+-label%3A%22backport+release-3_22%22> (same
>>> search should also be done with label `backport release-3_16`)
>>> Shouldn't backporting to 3.16 always imply backporting to 3.22 ? Or am I
>>> missing something ?
>>> Cheers !
>>> Olivier
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20211214/edaa1638/attachment.html>
More information about the QGIS-Developer mailing list
