[QGIS-Developer] Building QGIS with Visual Studio 2019 CE and vcpkg
DelazJ delazj at gmail.com
Mon Feb 1 01:49:04 PST 2021
Why not in the build instructions of the code repo instead:
https://github.com/qgis/QGIS/blob/master/INSTALL.md? If it's a working
process, easy to replicate, this is the place I'd expect this kind of
information.
Regards,
Harrissou
Le dim. 31 janv. 2021 à 15:55, Jorge Gustavo Rocha <jgr at di.uminho.pt> a
écrit :
> Hi Stefan,
> We have now a new tab on github called 'discussions'[1]. Your detailed
> instructions are a good candidate to write down a new entry there, under
> 'Show and tell' category. The goal is to keep this information next to
> the repo. You can use the markdown syntax to enhance the writing format.
> You can also add some print screens.
> This is just a suggestion. Feel free to put it there or not.
> Regards (and thank you!),
> Jorge Gustavo
> [1] https://github.com/qgis/QGIS/discussions
> Às 14:13 de 31/01/21, Uhrig, Stefan escreveu:
> > Install Visual Studio Community 2019: Select "Desktop development with
> > C++" under "Workloads" and "C++ MFC for latest v142 build tools (x86 &
> > x64)" under "Individual components". Verify that you install "Windows 10
> > SDK (10.0.18362.0)" or higher.
> > Install Git for Windows and Python 3.
> > Download
> https://sourceforge.net/projects/winflexbison/files/win_flex_bison3-latest.zip/download
> > and extract it to a location of your choice (avoid space characters in
> > the target path).
> > Follow the vcpkg "Quick Start: Windows" instructions at
> > https://github.com/microsoft/vcpkg#quick-start-windows. Make sure to
> > execute the "vcpkg integrate install" command.
> > Install the required dependencies via:
> > vcpkg --triplet=x64-windows install exiv2 gdal gsl libspatialindex
> > libspatialite libzip opencl protobuf qca qscintilla qt5 qt5-serialport
> > qt5-location qt5-winextras qtkeychain qwt zstd
> > This may take a while as this creates a Debug and a Release build of
> > each dependency from source.
> > Clone the QGIS repostiory. The path to the QGIS repository should not
> > contain any space characters.
> > Start Visual Studio and open the QGIS CMakeLists.txt file via "File -->
> > Open --> CMake...". This will start the CMake generation, which will
> > fail. You will need several configuration rounds until everything is
> > setup properly.
> > Let's start with a Release build because that requires less tweaking. Go
> > to "Project --> CMake Settings". Delete the default configuration
> > ("x64-Debug (default)").
> > Add a new "x64-Release" configuration and set "Configuration type" to
> > "Release". Save the CMakeSettings.json file, which will start a new
> > CMake generation. "FIND_FLEX" will fail, so you need to set the
> > "FLEX_EXECUTABLE" path manually in section "CMake variables and cache".
> > Browse to your win_flex.exe file. Additionally, disable "WITH_BINDINGS"
> > and "WITH_QGIS_PROCESS". Save the file. Next set "BISON_EXECUTABLE" to
> > your win_bison.exe file and save again. Disable "WITH_QTWEBKIT" and
> > save. Set "QCA_LIBRARY" to
> > "<vcpkg-root>\installed\x64-windows\lib\qca.lib" and save. Configuration
> > should now succeed, but you have to change "GEOS_LIBRARY" from
> > "geos.lib" to "geos_c.lib". Save and start the build after CMake
> > generation has finished.
> > Select "qgis.exe (output\bin\qgis.exe)" as start-up item in the toolbar
> > and start QGIS.
> > Now let's do the same for a Debug build. Add a "x64-Debug" configuration
> > and save. Change to the "x64-Debug" configuration in the toolbar. Repeat
> > the steps from above (set flex and bison paths etc.). When selecting
> > libraries, take the libraries from
> > "<vcpkg-root>\installed\x64-windows\debug\lib". Most libraries will have
> > a "d" or "_d" as name suffix. The CMake generation will not always
> > select the debug versions of libraries. Hence, go over the CMake
> > variables and change release library paths to debug library paths, e.g.
> > "<vcpkg-root>\installed\x64-windows\debug\lib\geos_cd.lib" for
> > GEOS_LIBRARY. I'll append my CMakeSettings.json file as reference to
> > this mail. Save again and start the build.
> > The build will fail because the execution of crssync.exe fails. That's
> > because crssync.exe tries to load zstd.dll instead of zstdd.dll. I
> > haven't figured out why, yet. An easy workaround is copying zstdd.dll to
> > zstd.dll in QGIS\out\build\x64-Debug\output\bin. Then restart the build
> > and it should succeed.
> > You should then be able to start and debug qgis.exe and its
> > dependencies. Note that some vcpkg portfiles forget to copy over the
> > .pdb files. For example, proj is affected. If you find such a library
> > with a missing .pdb file, check whether the portfile (e.g.
> > "<vcpkg-root>\ports\proj4\portfile.cmake") contains the
> > "vcpkg_copy_pdbs()" call. If not, just add it at the end, re-install the
> > dependency and copy over the .pdb file to the QGIS output directory.
> > I'm currently trying to get QGIS working with Python bindings. I got the
> > build working, however I'm struggling with the debug build execution.
> > The debug Python library seems to be unable to load the Release build Qt
> > libraries that come with PyQt5. Well, I'll keep trying and if I succeed,
> > I'll update the instructions.
> > Here is my CMakeSettings.json file for reference:
> >   "configurations": [
> >       "name": "x64-Release",
> >       "generator": "Ninja",
> >       "configurationType": "Release",
> >       "buildRoot": "${projectDir}\\out\\build\\${name}",
> >       "installRoot": "${projectDir}\\out\\install\\${name}",
> >       "cmakeCommandArgs": "",
> >       "buildCommandArgs": "",
> >       "ctestCommandArgs": "",
> >       "inheritEnvironments": [ "msvc_x64_x64" ],
> >       "variables": [
> >           "name": "WITH_BINDINGS",
> >           "value": "False",
> >           "type": "BOOL"
> >           "name": "WITH_QGIS_PROCESS",
> >           "value": "False",
> >           "type": "BOOL"
> >           "name": "FLEX_EXECUTABLE",
> >           "value": "C:/src/tools/win_flex.exe",
> >           "type": "FILEPATH"
> >           "name": "BISON_EXECUTABLE",
> >           "value": "C:/src/tools/win_bison.exe",
> >           "type": "FILEPATH"
> >           "name": "WITH_QTWEBKIT",
> >           "value": "False",
> >           "type": "BOOL"
> >           "name": "QCA_LIBRARY",
> >           "value": "C:/src/vcpkg/installed/x64-windows/lib/qca.lib",
> >           "type": "FILEPATH"
> >           "name": "GEOS_LIBRARY",
> >           "value": "C:/src/vcpkg/installed/x64-windows/lib/geos_c.lib",
> >           "type": "FILEPATH"
> >       "name": "x64-Debug",
> >       "configurationType": "Debug",
> >       "variables": [
> >           "type": "FILEPATH"
> >           "type": "FILEPATH"
> >           "value": "False",
> >           "type": "BOOL"
> >           "value": "False",
> >           "type": "BOOL"
> >           "value": "False",
> >           "type": "BOOL"
> >           "value":
> "C:/src/vcpkg/installed/x64-windows/debug/lib/qcad.lib",
> >           "type": "FILEPATH"
> >           "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/geos_cd.lib",
> >           "type": "FILEPATH"
> >           "name": "GSL_LIB",
> >           "value":
> "C:/src/vcpkg/installed/x64-windows/debug/lib/gsld.lib",
> >           "type": "FILEPATH"
> >           "name": "GSLCBLAS_LIB",
> >           "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/gslcblasd.lib",
> >           "type": "FILEPATH"
> >           "name": "PROJ_LIBRARY",
> >           "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/proj_d.lib",
> >           "type": "FILEPATH"
> >           "name": "QSCINTILLA_LIBRARY",
> >           "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/qscintilla2_qt5d.lib",
> >           "type": "FILEPATH"
> >           "name": "QTKEYCHAIN_LIBRARY",
> >           "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/qt5keychaind.lib",
> >           "type": "FILEPATH"
> >           "name": "QWT_LIBRARY",
> >           "value":
> "C:/src/vcpkg/installed/x64-windows/debug/lib/qwtd.lib",
> >           "type": "FILEPATH"
> >           "name": "SPATIALINDEX_LIBRARY",
> >           "value":
> > "C:/src/vcpkg/installed/x64-windows/debug/lib/spatialindex-64d.lib",
> >           "type": "FILEPATH"
> > *From:*i-s-o <46.i.s.o.64 at gmail.com>
> > *Sent:* Saturday, January 30, 2021 5:58 PM
> > *To:* Uhrig, Stefan <stefan.uhrig at sap.com>
> > *Cc:* qgis-developer <QGIS-Developer at lists.osgeo.org>
> > *Subject:* Re: [QGIS-Developer] Building QGIS with Visual Studio 2019 CE
> > and vcpkg
> > I am very interested in trying out your solution. Could you share the
> > required steps?
> > Thx.
> > On Fri, Jan 29, 2021, 09:25 Uhrig, Stefan <stefan.uhrig at sap.com
> > <mailto:stefan.uhrig at sap.com>> wrote:
> >     TL;DR: It is currently possible to build the QGIS core app with
> >     Visual Studio 2019 and vcpkg, which makes debugging QGIS
> >     dependencies easy.
> >     Hi all,
> >     Some time ago I discovered vcpkg
> >     (https://github.com/microsoft/vcpkg). vcpkg is a package manager
> >     that downloads package source code to your local machine and builds
> >     the package locally. Recently, I discovered that vcpkg should be
> >     able to provide all dependencies to build at least the QGIS core
> >     application. Hence, I gave it a try.
> >     Basically, it worked out of the box. I started with a fresh Windows
> >     10 installation, installed Visual Studio 2019 Community Edition,
> >     Git, vcpkg, Python 3 and flex and bison for Windows. I fetched all
> >     other dependencies via vcpkg. It was not necessary to even touch a
> >     single file in the repository. I could just open the main
> >     CMakeLists.txt file in Visual Studio and only had to tweak the CMake
> >     cache (the CMake find macros that come with QGIS are not aware of
> >     vcpkg, so I had to set some paths manually). I had to switch off
> >     some extensions though as the required dependencies were not
> >     available via vcpkg (WITH_BINDINGS, WITH_QGIS_PROCESS,
> >     WITH_QTWEBKIT). The build did not report any errors, I could start
> >     the application and it seems to work, but I did some light testing
> only.
> >     I mainly tried it because I enjoy debugging with Visual Studio more
> >     than with gdb (or gdb wrapped in some IDE). In my experience, the
> >     performance of the Visual Studio debugger is better and it is more
> >     stable, especially in long debug sessions.
> >     I don’t want to promote official building support of QGIS with
> >     vcpkg. Providing the dependencies via OSGeo4W is much more reliable.
> >     However, if you don’t mind the experimental nature of this setup and
> >     you want to be able to debug into QGIS’ dependencies, you might give
> >     it a try. Especially, if you want to track the cause of a crash in
> >     one of QGIS’ dependencies, this setup might be helpful. You have the
> >     source code and debug versions of the dependencies, so the debugger
> >     will jump to the crashing code line and you can inspect all the
> >     variables of the dependency.
> >     If someone is interested in trying it, give me a note. I can then
> >     assemble detailed instructions on how to make it work. It took me a
> >     while to figure out which packages are needed and how the CMake
> >     cache needs to be tweaked.
> >     Best regards,
> >     Stefan
> >     _______________________________________________
> >     QGIS-Developer mailing list
> >     QGIS-Developer at lists.osgeo.org <mailto:
> >     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Gabinete 3.29 (Piso 3)
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210201/5aaf21e6/attachment-0001.html>
More information about the QGIS-Developer mailing list
